351W F250 Intake Manifold Gasket Help
Hi all!
So I'm replacing the intake manifold gasket on the 1986 F250 351W 4 barrel (first time for me!).... I have the 8600 # truck so I have the intake manifold gasket with the "pan".. Manifold is stock.
I purchased the replacement feltpro gasket with the pan and gasket as one piece but the gasket that goes over the manifold appear to be 2 layers together. Like a double layer of gasket for each side... Is this right? Confused me because it doesn't appear the same as what I removed.
From reading the forums I know to ditch the end gaskets and use black RTV. RTV around the coolant passages. I have made guide bolts to get everything square as possible on install..
Should I use thread sealer/or RTV on the intake manifold bolts on the install?
Thanks!!
Thanks!!
Thanks for the documentation!!! that explains why I received the valley pan with the gasket attached acting as two layers...Hopefully this with fix my oil leak appearing to the left/right of the distributor..
Do you recommend just installing manifold bolts dry or should I use any thread sealer??
I use RTV to replace 9A424 & 425 - lots of RTV. And I set things down gently so as to not squeeze all of the RTV out until it starts setting up. Maybe snug up by hand and then torque it up the next day. And make sure everything the RTV touches is absolutely CLEAN - no finger prints or oil. Use brake cleaner or somesuch. Same thing for around the coolant passages.
And I use thread sealer or anti-seize on the manifold bolts. They are going into blind holes so there isn't an issue with leaks. I just like to ensure I can get them out. The real problem is with aluminum intakes - but I assume yours is cast iron.
No, sorry, that's only a sailboat anchor. Try a cast iron intake for an FE, like a 390, or one for a 460. Yours is heavy, but those are HEAVY!
In any event, make sure you use guide pins like you said you are going to do. And, take pains to lower it on the engine evenly from side-to-side. I've had problems with them going on at an angle and never straightening up like you would think they'd do.
Oldman570
Interesting project, I'm watching to see how this is going. My 85 Bronco has the same intake I suppose. And I'v'e been thinking of removing it..I must admit that aluminum Weiand is tempting to put back on...
I have a small oil dribble in the front as well..
good luck.
good luck.
good luck.
good luck.
