fuel gauge incorrect - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 03-13-2014, 01:40 PM
phase_one phase_one is offline
phase_one is starting off with a positive reputation.
I bought a 2001 expedition from a relative. The fuel gauge when full would read 3/4 tank. Fuel pump was not working. Mechanic shop replace fuel pump before I purchased the vehicle. The fuel gauge will only show 3/4 tank and go down to 1/4 tank. Fuel light never comes on. Ran out of gas twice. I have searched this page, sending unit could be bad is a possible problem. Fuel gauge could be the problem. Any other suggestions. Thanks!
Old 03-13-2014, 02:19 PM
alloro alloro is online now
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
It's a problem with the sender in the tank. Is the fuel pump installation under warranty?
Old 03-17-2014, 07:46 AM
arj1231 arj1231 is offline
arj1231 is starting off with a positive reputation.
had the same problem reading 3/4 when full. Turned out the people I bought it from changed the needles on the guages, with truck running I took apart the glass from the guages, pull the needle off and reposition it to a hair over full, tested with many restarts, and ran the truck near empty to see if gas light come on. no go. changed bulb and now works fine, light comes on about 1/8 tank, not sure if its correct but it works for me
Old 03-17-2014, 12:45 PM
lv2race's Avatar
lv2race lv2race is offline
lv2race is gaining momentum as a positive member of FTE.lv2race is gaining momentum as a positive member of FTE.
The float arm could be bent, it happened to me, probably during shipment. I didn't notice or compare it to the old one upon installation. Had to drop the tank again and compare the two to find out it was bent up causing the incorrect reading of more fuel then was in the tank.
Old 03-17-2014, 01:29 PM
r2millers's Avatar
r2millers r2millers is offline
r2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud of
I agree with all of the above. Since a mechanic installed, I'd take it back to him to ensure the sending unit is positioned correctly.
Did you check with your relative who owned it before to verify it read properly before the new pump.
If so, truly the mechanic needs to make it right.
Fuel gauge working but not accurate Ronnief150man 1973 - 1979 F-100 & Larger F-Series Trucks 5 12-04-2016 11:18 PM
Fuel Gauge Issue eutecticpt Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 04-24-2015 05:25 PM
76 f100 gauge cluster problem liv2roc 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-06-2013 12:23 PM
fuel guage stuck on full togobefastguy 1999 - 2003 7.3L Power Stroke Diesel 6 06-24-2012 10:37 AM
Fuel gauge acting strange... smallcandle Excursion - King of SUVs 2 10-13-2009 07:35 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
