shackles vs. spring packs - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-13-2014, 10:30 AM
NTENSE NTENSE is offline
NTENSE is starting off with a positive reputation.
I have an '03 7.3 CC 4wd with 35/12.50's on it. I have the front leveled by way of an extra leaf spring from the local spring shop. I like the way my truck looks right now but my tires scrub my fenders (not the liners but the rear corners of the fender flares) under very little compression. I was curious what the pros and cons were to each.
Old 03-13-2014, 02:12 PM
Airframes4life's Avatar
Airframes4life Airframes4life is offline
Airframes4life is starting off with a positive reputation.
my understanding of it is that shackles will change your caster and depending on how big they are can effect your pinion angle, i went with spring packs, theyre all over ebay for around 100 bucks with u bolts. ive heard a few horror stories of people shackling up the front and the drive shaft slides apart at the slip yoke leaving very little spline contact area and locking it in and stripping out the driveshaft... just my .02
Old 03-13-2014, 02:58 PM
bbender85's Avatar
bbender85 bbender85 is online now
bbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud of
running a mini pack on my current truck, trouble-free almost two years now. ran a lift shackle on my last super duty, along with 4" springs and had no ill-effects either. the caster/pinion angle concerns makes perfect sense in theory, but i literally couldn't tell any difference (and i wheeled that truck, wasn't a street queen).
Old 03-13-2014, 03:07 PM
benfishn benfishn is offline
benfishn is starting off with a positive reputation.
It's hard to go wrong with springs packs. Shackles can open up a whole new can of worms like Airframes4life stated, and can end up costing more in the long run. Since shackle lift only give you half amount of lift, you are going to need a lot of shackle to get any decent lift. I think anymore than 2'' (1'' lift) of shackle is beginning to pushing it.
I would just use lift blocks and be done with it.
Edit: The "lift blocks" was pure sarcasm. It is the absolute wrong way to do it.
Old 03-13-2014, 03:18 PM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is online now
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
its illegal to run front blocks in ANY STATE plus DANGEROUS, just buy a 4" lift kit with new front springs and be done with it, plain and simple
Old 03-13-2014, 03:22 PM
MisterCMK's Avatar
MisterCMK MisterCMK is online now
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
Quote:
There are no laws in MN and many other states regarding front blocks.
It is still a bad idea though.
AlaskanEx's Avatar
AlaskanEx AlaskanEx is offline
AlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputation
I've been running 2.5" lift shackles (provided 2.5" of lift) for going on 4 years and 32k miles and half of that is running in 4x4 high during the winter every day for 6 months.
absolutely no issues with steering, front drive shaft..ect
Old 03-13-2014, 03:27 PM
before i put my new pro comp 2.5" springs on i had the stock 4400lb front springs+tuff country 1.5" add a leaf+ 1" pro form lift shackle for almost four years and i never had any handling issues, other than a dump truck ride from the add a leaf. I changed the springs because i couldn't take the ride anymore and im debating adding my 1" lift shackle again to get me a little extra height up front
Old 03-13-2014, 03:29 PM
Your shackles are 5'' longer that stock ones?
My experience with lift shackles on my old FJ40 is the extra side to side leverage they provide. It makes the death wobble more possible.
Old 03-13-2014, 03:51 PM
AlaskanEx's Avatar
stock on the bottom new lift shackle on top
before
after
Old 03-13-2014, 07:30 PM
Quote:
By springs do you mean spring packs?
Old 03-13-2014, 07:38 PM
In order to get the full 2" did you shackle both ends of the spring? Seems to me if you lift one end of the spring 2", by the time you go halfway back, where the axle is, you'd loose half the lift.
Old 03-13-2014, 07:55 PM
Will spring packs effect the ride or handling? Another question I've had since researching this topic is in regards to lift blocks. If the main concern is them getting spit out, why would a bolt through the center like the spring packs not work?
Old 03-13-2014, 08:09 PM
AlaskanEx's Avatar
Quote:
No, the front end of the spring does not move that mount stays stock. The longer shackle goes on the rear end of the spring.
Old 03-13-2014, 08:10 PM
Yes leaf spring packs.
From my experience paying the extra to do it right the first time saves you money, time, frustration, and is safer.
Rear Fender bolts Indybeer 1948 - 1956 F1, F100 & Larger F-Series Trucks 19 09-23-2016 12:15 PM
What to use to paint my hood hinges rhw Paint & Bodywork 2 05-26-2016 12:43 AM
48 f1 front fender height train2 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 05-11-2012 01:48 PM
why does my truck sit so freaking low? xc4jokestomper 1987 - 1996 F150 & Larger F-Series Trucks 18 05-01-2011 09:59 PM
Can I get an underhood pic? glovemeister 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 04-18-2011 03:32 PM
Tags
leaf spring, lift, minipack, shackle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
