shackles vs. spring packs - Page 3 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
  #31
Old 03-20-2014, 11:40 AM
NTENSE NTENSE is offline
NTENSE is starting off with a positive reputation.
Quote:
Originally Posted by EXv10 View Post
Blocks in the front? By mini-packs do you mean the little short spring pieces?
Nah, no blocks in the front. Just in the back. And yes mini packs being the little short minis with the rod or bolt through them.
  #32
Old 03-20-2014, 01:44 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
Quote:
Those are expensive garbage and unsafe in the front, plus they do nothing for spring clearance.
  #33
Old 03-20-2014, 06:15 PM
I was gonna go with 2" lift shackles up front for tire clearance.
  #34
Old 03-27-2014, 09:57 PM
big specht big specht is offline
big specht is starting off with a positive reputation.
As for front blocks being so bad. Why is about every heavy duty truck with front leaf springs have a lift blocks?? If you dont think so look at the next heavy truck you see. AND those trucks dont have track bars to center the axle. Just my .02 on this topic.
  #35
Old 04-14-2014, 10:59 AM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is offline
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
Quote:
well my two truck's don't. 1995 GMC Top Kick 37k GVW no blocks up front leaf sit right on the front axle, 2005 Freightliner 37k GVW front leafs sit on axle
  #36
Old 04-14-2014, 12:38 PM
They probably don't want novices using blocks (not saying you are.) Those blocks you see probably have well fitted holes and pins in them etc.
Rear Fender bolts Indybeer 1948 - 1956 F1, F100 & Larger F-Series Trucks 19 09-23-2016 12:15 PM
What to use to paint my hood hinges rhw Paint & Bodywork 2 05-26-2016 12:43 AM
48 f1 front fender height train2 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 05-11-2012 01:48 PM
Radius Arm Bushings Dillan Reese 1961 - 1966 F-100 & Larger F-Series Trucks 4 05-10-2012 09:50 AM
why does my truck sit so freaking low? xc4jokestomper 1987 - 1996 F150 & Larger F-Series Trucks 18 05-01-2011 09:59 PM
Tags
leaf spring, lift, minipack, shackle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
