HELP!!! 08 E150 with a 4.6 no compression 2&4 - Ford Truck Enthusiasts Forums
Old 03-13-2014, 01:09 AM
Bercojr Bercojr is offline
Bercojr is starting off with a positive reputation.
Ok, so I've got a 2008 E150, and I've got no compression on cylinders 2&4, so i pulled both of the heads, did a valve job along with replacing all the valve springs. Put it all back together and still no compression. So I pulled the motor and tore it down, the ring were bad, so i put all new rings in it, put it back together still no compression on 2&4, I thought the lifters might be locking up, so i replaced those as well, STILL NO COMPRESSION ON 2&4 , i don't know what to do now. If i pull the lifters out, so the valves are closed, and shoot air in the cylinders there are no leaks, and it holds compression, but as soon as i put the lifters back in it has no compression again, but like i said these are brand new lifters. I have run out of ideas and really need some help, also i replaced the EGR valve thinking maybe exhaust was some how getting into the head causing, and i replaced the PCV valve, but nothing works. It makes no sense to me what could be going on. Please help!
Old 03-18-2014, 01:21 AM
MJE426 MJE426 is offline
MJE426 is starting off with a positive reputation.
Have you tried swapping the cam followers from a good cylinder to the bad cylinder? Also check the cam lobes for the bad cylinders, they could be bad.
Old 03-18-2014, 03:42 PM
Quote:
I haven't tried that yet, I will then I will let you know
95 valve adjustment issue markfuga Ford Inline Six, 200, 250, 4.9L / 300 16 03-04-2016 08:51 AM
93 F150 4.9L engine trouble Milpool 1987 - 1996 F150 & Larger F-Series Trucks 8 01-31-2016 11:13 PM
Rocker arm Glenn.b1 1999 to 2016 Super Duty 5 07-05-2015 06:09 PM
Most confusing diagnostic ever..... cyclone-429 1957 - 1960 F100 & Larger F-Series Trucks 4 01-30-2015 05:39 PM
heads bieng redone. please help. Zac2zac2 1967 - 1972 F-100 & Larger F-Series Trucks 26 12-02-2014 11:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
