Shot Peening in Tulsa Area??
Well, I may have answered my own question, but I'd still like your input. Anyway, I think I've found the place for having shot peening done. Talked to Fred at United Plating Work and took these notes:
- $75 for a set of 8 rods if they have to mask the bores, and $50 if not
- They are an aerospace company and do it quite scientifically. They measure the thickness of the part and refer to a MIL Spec that gives them the guidelines as well as the required test strips. They load up with the appropriate shot, set the PSI, and shoot against a test strip that must arc to a certain height. Then they shoot the part, and then shoot a test strip when done to prove they are still in calibration.
- A media blast cabinet like mine won't have enough vacuum to pull the steel shot properly. They use an elevator system that raises the shot above the work and then introduce the air as the shot falls.
- Proper shot peening increases the fatigue life 10x. For instance, if you took a part that would work-harden and fail after 10 bends and shot peened it the failure point would be somewhere beyond 100 bends.
Just as a follow up, here's what I posted in Dad's Engine thread on the 80 - 86 forum:
Picked up the rods after having them shot-peened. Here's a before pic:
And here's an after:
Then a close-up of the numbers, for reference, showing the surface texture:
Here's a blurb from http://en.wikipedia.org/wiki/Shot_peening on shot peening:
Depending on the part geometry, part material, shot material, shot quality, shot intensity, shot coverage, shot peening can increase fatigue life up to 1000%.
Fred said that if you were able to shot peen a piece of wire that would normally work-harden and break when you bent it 10 times, that it would go over 100 times after shot peening. And he basically said I won't be able to break those rods, that other parts of the engine are now the failure point, not the rods.
ampslw
04-10-2010 07:28 PM
Secret Agent 069
02-24-2008 01:30 PM
