Telescoping steering wheel - Ford Truck Enthusiasts Forums
Old 03-12-2014, 12:38 PM
Jonesy0027's Avatar
Jonesy0027 Jonesy0027 is offline
Jonesy0027 is gaining momentum as a positive member of FTE.
Hey Fellas,
I have a question for you guys. Owned my truck since 12/28/2013, without telescoping steering wheel. I'm 5'10" and 190lbs, not a big guy by any means. I've never really been comfortable with the drivers seat position with the steering wheel and adjustable pedals. I figured(it was me) and it would take me a while to find a comfortable driving position. When I move the seat close enough to the steering wheel for comfort for my arm position, my knees hit the dash. So I move the tilt wheel all the up and drop the seat all the way down, which is uncomfortable for me. Guess I'm old and crabby.
Anyone else experience this issue?
Wondering if the dealer would even be able to ADD telescoping wheel and how much the dealer would charge? Arm... leg...
Let me know your thoughts. Adios.
Old 03-12-2014, 02:22 PM
tvsjr tvsjr is offline
tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.
Best I can tell, column shifter and telescoping wheel are mutually exclusive. I have a similar but different concern - I would like to buy an FX4 next time around (which is telescoping), but I need a column shift rather than a floor shift.
To convert yours, you would have to totally replace the steering column, and add the floor console with shifter. Expect several thousand dollars, if you can find anyone willing to do it.
Failing that, your only other viable option would be to trade the truck in on a variant that has the telescoping wheel (FX2/FX4, Platinum, KR... maybe some Lariats).
Old 03-12-2014, 02:39 PM
QwkTrip's Avatar
QwkTrip QwkTrip is offline
QwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to behold
I also thought the seating was created for a monkey and not a man. Eventually I did get used to it. It helps to have a very upright seating position.
Old 03-12-2014, 05:18 PM
Big-Red-Lariat's Avatar
Big-Red-Lariat Big-Red-Lariat is offline
Big-Red-Lariat is starting off with a positive reputation.
would likely be cheaper an safer to trade the truck if you really want this option, rather than having someone monkey with your steering column, and take a can opener to the floor to install a stick shift! My Lariat has it; not sure if it is a Lariat standard, or option. Good luck shopping.
New V10 F350 purchase, looking to do a full front end rebuild alabbasi 1999 to 2016 Super Duty 6 10-08-2016 12:47 PM
Learn something new everyday edjunior 1999 to 2016 Super Duty 10 05-27-2016 02:32 PM
Power telescope/tilt malfunctioning Ford79 1999 to 2016 Super Duty 4 10-17-2015 09:16 AM
Seat reclining mechanism Mikeman Aerostar 6 03-16-2015 06:39 PM
Anyone else think the location of some warning lights is poor? troverman 1999 to 2016 Super Duty 6 11-12-2014 08:06 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
