Started normal then abrupt stall - no fire
Truck has been running great lately. Started up normally this am and while idling after about a minute (maybe a little less) it just quit altogether. Turns over just fine, but won't fire now. Tried long glow plug cycle thinking maybe fuel pump had a hiccup, but still doesn't fire.
Fresh tank of gas in it about 5 miles ago. Water??
Any ideas where to start troubleshooting? Thanks in advance!
On your scangauge, here are the codes for it:
Injection Control Pressure
07E0221446
046205140646
3010
003900640000
ICP
PSI
500 psi is required for the engine to start, any less and you're going nowhere.
Highest that the ICP read on SGII was 241, though I'm reading that the SGII can lag significantly. Temperature is just above freezing here so everything somewhat slow - including me.
Cranking slower after a few seconds leads me to a new very stoopid question...
How do I hook up my 12 volt charger (with 100 amp start function) to the system so that i can help this thing crank and get meaningful readings?
Going to program IPR into the SGII while a wait for a reply. ANything else?
Very much appreciate the help here.
That don't look good...
Chances are if that's messed up, the one below the HPOP resevoir needs some attention too.
You could get away with it, but you could also just replace the IPR and be good.
If it were me and I had the cash, I'd make sure HPO resevoir screen was clear of debris and the o-ring between the discharge tube and HPOP hadn't disintegrated.
