SuperCab 4x4 Resto-Mod Cummins Swap Build
#62
#64
#65
Ford Rear Disc Brake Kits for 9", Dana 60, Dana 70 and Sterling
The ones I got are halfway down the page, brackets only. The whole disc conversion only cost me about $200 give or take. Not bad!
#66
#68
Engine Fitment
Ok, this is gonna be a pain. I was warned I would have to cut the crossmember, and sure enough. I got ahold of a set of "Conversion Specialists" motor mounts for this, and I went back and actually read the instructions (not much of an instruction guy normally). They state that you have to "notch the crossmember, you don't need to cut it, just notch it". Well apparently when they mean by "not cut it" is to cut the hell out of it. What the? Anyway, here is my first test fit with more to follow.
This is what I figure I will have to cut out. That sucks.
Yeah, that's a lot. I'm sure I'll be doing several more test-fits before I box this thing in.
#69
#70
#71
Ohh, also the kit for the motor mounts that you got, did you get the kit to go in a 4x4 truck, if so the cross member is in a totally different location and the notching would have likely been dramatically less, the 4x2 frames crossmember is right in the way though so thats why you have had to cut so much
#72
#73
