Rubber firewall matting
How effective is the rubber matting on the exterior of the cab? I assume this is only on diesel trucks. Mine isn't in very good shape and the fiberglass insulation behind it fell off.
Would I be better served ripping it out and adding more sound deadening inside the cab?
If you mean the stuff with foil on it, that's for heat insulation more than it is for noise.
I took all the jute padding out from under my rubber floors, and removed all the foam from the firewall too (inside the cab) since I had a leak and it was soaked and causing more rust damage. Not all that much louder inside than it was before I removed it... definitely noticeable but not bad, but then again I don't likethe inside of my truck to be dead quiet either.
4xfourdoorFloyd
01-11-2012 05:49 PM
FESTER1st
06-17-2008 02:42 AM
