miss on engine 06 escape. - Ford Truck Enthusiasts Forums
Old 03-11-2014, 09:14 PM
flanders123 flanders123 is offline
flanders123 is starting off with a positive reputation.
I have an 06 escape and it has a slight miss. But the engine light wont turn on. Now I don't kno what it is. Plugs or a coil??
Old 03-24-2014, 01:24 AM
ajwgator ajwgator is offline
ajwgator is starting off with a positive reputation.
Really depends upon how many miles are on it. Have you ever changed the plugs as of yet? Most of the time after 100K the plugs really need to be changed no matter what. They can break down with that many miles on them and you will feel a slight miss under a bit of load. The coil packs are definitely a probable cause for a miss. Look for cracks in the tops near the area where the wires plug into them. The cracks allow a short to ground and will not allow the spark to get to the plug.
Usually this type of miss will not trigger a check engine light. Just plain ole old fashion maintenance techniques from before the days of computers....
ABS light, code C1473 on 06 Escape Hybrid Badas Bill Escape & Escape Hybrid 0 06-18-2015 02:40 PM
06 Escape ECM communication Ford_Six Escape & Escape Hybrid 7 03-25-2015 11:24 PM
Friend's 2006 Escape Hybrid had rear-end come loose from rusted frame jbullfrog Escape & Escape Hybrid 2 03-07-2015 10:34 AM
2001 escape just won't run itswrongway Escape & Escape Hybrid 2 12-03-2014 11:26 PM
'06 Ford Escape Hybrid - Engine doesn't shut off at stops zich6 Escape & Escape Hybrid 2 09-02-2014 07:56 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
