1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
questions about 2014 F250 vs F350
Old 03-11-2014, 10:56 PM
Stanggt24's Avatar
Stanggt24
Stanggt24 is offline
Originally Posted by bell4fan
Yeah I believe so. There was only one SRW 350 on the lot, but it had the 4 inch blocks.
Ive seen several people on here say the '14 250's have 4 inch blocks also, but I haven't seen one yet.
After new blocks
Old 03-11-2014, 10:58 PM
bell4fan's Avatar
bell4fan
bell4fan is offline
Man I love that color. Had a 03 just like that. Back then it was True Blue instead of the blue jeans metallic, but its close enough. I did an impulse buy on a white one, probably my 2nd fav color behind the blue.
Stanggt24's Avatar
Stanggt24
Sorry after blocks my iPad is acting up tonight !!!
Old 03-11-2014, 11:12 PM
bell4fan's Avatar
bell4fan
bell4fan is offline
amazing what that extra 2 inches does.
Old 03-11-2014, 11:14 PM
Stanggt24's Avatar
Stanggt24
Well the way my guy explained it to me it ends up being more then 2" because u have to factor in the rake from the point of where the blocks are to the very back of truck
Old 03-11-2014, 11:19 PM
bell4fan's Avatar
bell4fan
bell4fan is offline
Interesting. Sad thing is we are buying these $50k trucks and having to immediately mod them to make them set how a 3/4 ton truck SHOULD set from the factory.
Old 03-12-2014, 05:08 AM
senix's Avatar
senix
senix is online now
Received 1,415 Likes on 1,010 Posts
Very nice! I bought mine off the lot with the camper and snow plow prep as well.
Old 03-12-2014, 08:59 AM
spud57's Avatar
spud57
spud57 is offline
You would also have to replace the U bolts?
Old 03-12-2014, 10:35 AM
marcs724's Avatar
marcs724
marcs724 is offline
Couldn't agree more!!!!!!! It used to be you only had to add airbags or something if you were hauling stuff you probably shouldn't really be hauling anyway. But now (or with my '12 at least) I had to add airbags just to keep it from looking like a dog dragging its @$$ across the carpet with just a moderate load, well within capabilities. Personally I'll never do airbags again, they've been a total disaster for me. But hopefully I'll never have to, since the '14 seems to be a lot better in this area.
Old 03-12-2014, 10:57 AM
senix's Avatar
senix
senix is online now
Bigger blocks mean bigger u bolts. Plus it is not a good idea to reuse those.
Old 03-12-2014, 07:52 PM
Stanggt24's Avatar
Stanggt24
Yes u need longer u bolts which they replaced when they installed my new blocks on truck !!!!
Old 03-13-2014, 06:19 AM
spud57's Avatar
spud57
spud57 is offline
Do you happen to have the part numbers fir the blocks and u bolts?
  #28
Old 03-13-2014, 09:06 PM
Stanggt24's Avatar
Stanggt24
The place that installed them told me to go to a local ford dealer and climb under a f-350 and measure blocks then get vin number on truck if it has the 3 1/2 " blocks then have them look them up and order them. As far as the u bolts my spring shop I believe made new ones or had them there at there shop. I will look in my garage I might have the box the new blocks came in I will look tomorrow Rich
  #29
Old 03-14-2014, 10:21 PM
bell4fan's Avatar
bell4fan
bell4fan is offline
I did the ready lift 4inch blocks. Came with everything. $315 installed.
  #30
Old 03-15-2014, 03:58 AM
F2502011's Avatar
F2502011
F2502011 is offline
That's what she said.
F250s have the same rear blocks they've always had for this body style anyway. The confusion has happened because some dealers started installing the F350 blocks in new F250s before putting them on the lots to sell making it appear that there had been some change, but there hasn't been any change. If you see an F250 with its hind end higher than than level with the front wheels someone has done something to it since it left the factory.
F250_6_2
2017+ Super Duty
08-17-2017 08:21 AM
Kevin's dad
2017+ Super Duty
08-16-2017 04:04 PM
tomstoner06
6.7L Power Stroke Diesel
17
03-24-2013 08:00 PM
Gold Dog
19
08-19-2009 06:39 PM
grmnrkt
13
12-08-2008 07:12 PM
Quick Reply: questions about 2014 F250 vs F350
