F250 Dually?
Old 03-11-2014, 05:31 PM
Areyouliving's Avatar
Areyouliving
Areyouliving is offline
F250 Dually?
Bought this truck recently, it's a 1990 F250 Dually 4x4 xtra cab. Has a 460ci and e40d that I just had rebuilt. Is there any way to tell if this is a factory setup vs a conversion? Some kind of VIN check?
I bought a nice pair of rear fenders for it, and a front clip from a 1994 F350. I use it for towing my boats. I want to level the front end and lift the truck about 2-3". The way it current sits the hitch is too low for most of the boats I tow. Suggestions on lifts to accomplish that are appreciated as well. I'm going to sell the current front clip pictured as well, other than faded paint its very clean.
Here's some pics.
Old 03-11-2014, 06:17 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,153 Likes on 911 Posts
There never was a F250 dually from the factory, it's a conversion.
Old 03-11-2014, 07:07 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
RLA is Correct. It is a conversion of some sorts.
I am sure you will find spacers in the rear and adapters in the front. Along with a butchered bed to put the fenders on(NOT factory ford fenders, they are one off conversion fenders that are completely different than the factory ones)
Arrowcraft is a company that makes conversion parts
Old 03-11-2014, 08:28 PM
Bierisch's Avatar
Bierisch
Bierisch is offline
Another thing is that it is a 4x4, as far as I know there weren't factory 4x4 duallies. Right, guys?
EDIT: Also, besides those fenders, that is a spiffy looking ride you've got.
Old 03-11-2014, 08:31 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
not in pickup form like that there wasn't nope.
Old 03-11-2014, 09:22 PM
eakermeld's Avatar
eakermeld
eakermeld is offline
Dana 60 dually hubs will fit on a Dana 50TTB front, if anyone cares to know.
Old 03-11-2014, 09:56 PM
Bierisch's Avatar
Bierisch
Bierisch is offline
What do you mean pickup form? Like with the bed, as opposed to cab & chassis?
Old 03-11-2014, 11:29 PM
FORDF250HDXLT
right.the f350 cab n chassis (which are all duallies) did come in 4wd too.
Old 03-12-2014, 12:19 PM
Areyouliving
Lots of good info, thank you. I'm going to pull the rear wheels this weekend and l'll look for spacers etc. On the front though adapters for what?
Old 03-12-2014, 01:13 PM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,081 Likes on 2,151 Posts
does it have a solid front axle, or IFS?
Old 03-12-2014, 01:29 PM
Areyouliving
IFS, I wish it had a straight axle, and I'm sure before too long it will.
Old 03-13-2014, 05:20 PM
Diesel_Brad
The rear would have 3" spacers bolted on to the lug studs and then the 2 dually wheels would bolt to that.
For the front, there would be a 6" spacer that bolts on to the lug studs then the tire would bolt to that
Here is what a Singe wheel front looks like
Here is a factory Front dually hub(top of pic) 2" spacers in lower part of pic
And stock rear dually axle
Here are some pics of the Arrowcraft spacers/adapters
Adaptors, Wheels, Duality Fenders and Complete Kits - Arrowcraft :: Helping You Handle the Road for over 30 years!
Old 03-13-2014, 06:01 PM
FORDF250HDXLT
arrowcraft aa4's here on mine:
Old 03-13-2014, 10:28 PM
Truck Guy99's Avatar
Truck Guy99
Truck Guy99 is offline
Correct. All duallys that are pre-super duty were only available in 2wd except for cab and chassis trucks. Also, all duallys are F350, there was never any F250 dually from the factory. I would be interested in the front dually adapters if your interested in going back to single wheel.
As far as how to lift it, go with lift springs. If you ever plan to off road, don't go with lift blocks or body lift. If you're only lifting it because of the trailer height, I'm assuming you're using a bumper ball instead of a receiver hitch. If this is the case, take out that ball and bolt on a receiver with a raise hitch. A receiver is very cheap compared to a lift and won't open up a can of worms called suspension
Old 04-01-2014, 04:20 PM
Areyouliving
Would spacers like this make a trucks turning radius terrible? There's not enough room on a 6 lane freeway for a uturn in this truck.
Quick Reply: F250 Dually?
