Can an oil leak at the VCT cause lean codes? - Ford Truck Enthusiasts Forums
Old 03-11-2014, 05:30 PM
jkinghorn6.0's Avatar
jkinghorn6.0 jkinghorn6.0 is offline
jkinghorn6.0 is starting off with a positive reputation.
I have an 06 F250 5.4 3v with 132500 miles which I have lean codes for both banks. I have replaced both cats, MAF, the vacuum elbow, the break booster vacuum lines and the throttle body motor and gasket. I can't find any other vacuum leaks but I am leaking oil at the driver side VCT can that cause any problems or what else can cause lean codes
tough one - misfire and already checked the most common things zephyrprime 1999 to 2016 Super Duty 12 02-11-2016 10:28 PM
Lean Codes 1996 F150 Barbarosa57 1987 - 1996 F150 & Larger F-Series Trucks 9 01-04-2015 03:14 PM
08 f150 knock f150guuy 2004 - 2008 F150 1 09-04-2014 01:59 AM
oil leak at VCT cap seal jkinghorn6.0 Modular V8 (4.6L, 5.4L) 0 04-07-2014 09:46 PM
Questions about VCT System - P0012 and P0021 Codes jtillery 1997-2006 Expedition & Navigator 6 02-15-2014 02:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
