Side Window Deflectors F-350
I got the 14 also. I tried the Weather techs but they do not work, there was a piece that was jamming the window preventing it from going up..I am sick of there in channels with FORD trucks, with the auto-up feature they kick back and are a tight fit causing the motor/window to wear. Never worked right on my 13 F150. I chose to go with the FORD OEM's this time. There a peel and stick but are nice, sleek, tinted, and only stick to the black window trim and not the paint. I will be installing tomorrow since it is the first 70 degree day were gonna get. The 2 rears are easy, the front 2 require to loosen the mirrors to allow to slide the visor in and stick then tighten mirror..There is a good YouTube install video of guy installing on his new SD..
I've always had great results using The Original AVS Ventvisors. I've even successfully removed and reinstalled them from one truck to another. In my opinion, you can't go wrong.
I prefer the adhesive mounted vent-visors. I've found the "in channel" visors put too much stress on the window/window frame for my liking.
Just clean, clean, clean the surfaces with alcohol before installing. And if possible, wait for a warm day with lots of sunshine.
I have the OEM FORD 1's on my 06, and have installed them on several vehicles with great success. They fit great, hold up to several car washes a year, most with my company truck through a mechanical car wash, and they don't fade or dull like the A/M ones.
That is also true of the bug guard. I went through 3 lunds on my 06, and finally switched to the FORD 1 and haven't had an issue with it fading yet. '
Sarge
Sarge
