09 F250 5.4L Fuel gauge stays on empty
I filled up my tank and several days later the fuel gauge went to empty and the fuel light is on. When I turn the key on, the gauge goes below empty and turn key off, it goes back to empty mark. I have held down the odometer reset/select button for 10 seconds and then turn on key so it goes into engineering mode and do a gauge sweep, and the fuel gauge does a full sweep. I have ran 2 bottles of Techron thru it. I disconnected the main connector that goes to the back, under the master cly, and it read 99 ohms yest. and drove it today and it now reads 96 ohm. I called the local dealership yest. and the guy told me they could re-flash the cluster for $50 to try to fix it. I called back today to get an app. and a new guy said doesn't think re-flashing do anything.
Does anyone have any suggestions on what to do? Has anyone ever had theirs re-flashed? I'm at a lose on what do next.
It has no trouble codes.
The wires I am probing in the harness are yellow/violet and green/blue
After thinking about it, I wanted to see it in action so I jacked it up and then had someone let it down so I could watch the MM. It jumped all over the place from 0 to 1000 and after a few minutes it settled back to 96. So I guessing being perfectly still it works, but movement makes it spazz?
I'll try the sending unit. Thanks for the advise.
Pulled the sending unit and it works fine. Had a friend look at it with his Matco scan tool and he said the fuel reads almost half of tank.
I sent the cluster here Brian's Speedometer Repairs - Home - Muldrow, OK. Will see what he says.
I got my cluster back and the fuel gauge works. He said the #23 green/blue trace wire was fried (#24 yellow/violet is the other wire from the sender). It is still a mystery why/what fried it...was it a fluke or is there something in the harness or cluster that caused it? Fingers crossed that it was a stray gremlin.
hairymonster
03-09-2016 09:02 AM
