Need Help with door installation and line up
Hello
I'm Stan, and I need help to reset the doors on my sons truck. I hope this is the right place to start and if not could you please direct me to that spot.
So lets start out with why we took off the doors, My son is 16 and wanted to redo a truck to be able to say he did it and be proud of what he has accomplished, but he got in way over his head and tore it apart to make it easy to work on the floor to patch hole in it. He's done really well up till this point and I'm proud of him. He now needs to put the doors on and reline them up and can't get it right to close the doors and keep them from hitting the fenders. If you have any pointers that would make this easy and get them done I and he would greatly appreciate the help. Thanks in advance.
Stan
Stan
Hello scooter79 and thanks for the help that's a great idea for spacing never though of that. I have another question then on how to get the door in far enough to line up with the body? We have been messing with this for two days and can't seem to get it to stay after we open the door up to tighten the bolts. We are trying to not remove the fenders seeing how we just put a new drivers side on and boy was that ever a pain to do. If its nothing more then tweaking a little at a time then that's what we'll have to do.
Thank you
Stan
Thank you
Stan
Welcome to FTE. I had to take my doors off to drill holes for speaker wiring. I used my cherry picker with some cardboard and chains around the top of the door to "hang" the door while I lined up the hinges. This freed up my hands. I was able to use the dirt around the hinges as a guide to put them back where they were. No issues with alignment but if your surfaces are clean you're basically starting from scratch. In that case all panel alignment is trial and error.
Hello fmc400
Thanks for the welcome and the help. That's what I thought we would have to do but wanted to see if there was a trick that would help. Your cherry picker is a good idea and I thought of something better and that's a jib crane. I used to sell parts from salvage motorcycles and had one built to lift them and motors around the garage. I'll have to post pics when I get time and pics of my sons truck.
Thanks for all the help
Stan
Stan
A little late to say he should of scribed marked the hinge position BEFORE HE REMOVED THEM....yes to late now. FYI works for the hood too.
Do not loosen the hinge of the door, you will be chasing your tail even harder. Like it was said, is there any prior position dirt marks to use? Set the height first with paint sticks or get some house door frame wooded shim pack and use pieces under the bottom of the door and use the body lines to set it.
Support the door as much as possible when opened, roller floor jack and 2 ft long 2x4 with a groove cut in it length wise for the door, put the door on, tighten hdwr as much as possible, but still be able to work the door around.
Once you get the height set with the body lines right, get in there any way possible to scribe mark/ sharpie the top and bottom hinge position. That way when you open it and it slips you have a mark to go back to.
Put some masking tape on the door and fender edge to prevent damage. Open the door only enough to get a scribe in there.
It is not a fast process, if you get frustrated take a soda break, and talk future truck plans. Stop by here more often before tasks are started.
Hang in there.
Hang in there.
I haven't done any doors on mine yet, but here is how I have done my other parts. Snug things down just a little, enough it will sorta stay but loose that you can use a little prying to move. I would probably do the front to back first and up and down first, then do the in and out. I would set the door to the back as far as I could, then if it needs to come forward litely pry it forward. if you get this lined up decent, then tighten down and do the in and out. same way. good luck, hope this is understandable. Makes sense in my head.
Hi Stan,
Welcome to the site.... you'll find lots of ideas and help here.
The ideas in the above posts for supporting the door are key to an easy install. I use a tool that fits on my floor jack. I don't remember where I got it. I work alone so it makes hanging doors possible for me.
Keep at it and good luck on your project.
Hi everyone
Just want to say thanks for all the help. We did get the door set and lined up the paint sticks helped a lot to set the door in place, and we have long extensions to reach in be hind the fender to tighten it when the door was closed. Hey fuzzybob that's a nice door jack setup wish we had that for him to use he would have done the job with out me just so he could say he didn't need any help. He's very independent and loves to be able to say he did it. The truck is now out for inspection today, hope it passes so he can use it for a daily driver and stop pesting to drive it illegally. Hey I just looked back and saw that I didn't tell everyone the truck is a 1978 F-150 custom 4 speed 4 x 4 and we are the second owner, how cool is that.
Congrats to you both on getting the door aligned. Sounds like a good kid with a nice truck. You are new so I won't crack on ya, but you need to post some pics, its the unwritten rule. lol
Make sure to stop by the tips & tricks thread for more great info.
https://www.ford-trucks.com/forums/1...ease-read.html
Also there is a "Next Generation" forum for the 15 to 25 age group of Ford truck owners, that might be cool for him to ck out?
The Next Generation - Ford Truck Enthusiasts Forums
Also make sure and join your state FTE chapter for maybe some local help also.
Pennsylvania Chapter - Ford Truck Enthusiasts Forums
And welcome to FTE.
And welcome to FTE.
Thanks 77&79F250 he is a good kid and has worked on all kinds of things from the age of 3 and its never stopped. He is in tech for diesel mechanics and is going to go to a collage to further his education and walk away with a degree in diesel mechanics.
I think he's on the right path and it keeps him out of trouble and away from the drug seen, and to me that's everything in my book.
Well we just got the bad new on the inspection and it turns out that he needs to do more wielding on the cab. We didn't notice how bad the cab corners were and now we need to put in new. The exhaust needs some work also along with fender wells need plastic just to get it to pass. All in all it not as bad as it could have been and we should have it done by the end of the weekend if all goes well.
