02 f250 4x4 issue
Old 03-11-2014, 12:02 PM
winterkill's Avatar
winterkill
winterkill is offline
02 f250 4x4 issue
my four wheel drive is working intermittenly. i heard to test the vacuum system you can cycle the vents and if there was a leak it would stay on defrost.??? the vents are working properly. i can hear the vacuum pupm working on the passenger fender well. however the 4wheel drive seems to work off and on. this morning it didnt then i drove for 15 miles and it worked. i have the hubs in auto. the indicator light comes on and off on the dash when i cycle the switch. anyone have ideas, is my 4x4 solenoid in question.??
Old 03-11-2014, 02:07 PM
Dan V's Avatar
Dan V
Dan V is offline
Most likely a vacuum leak...It could be anywhere downstream of the PVH solenoid...ie: lines, inner axle seal, outer locking hub o-ring. Your best course of action is to borrow or buy a hand held vacuum pump like a MityVac. Then start tracking the leak down.
Old 03-11-2014, 04:01 PM
HKusp's Avatar
HKusp
HKusp is offline
How are you determining whether or not the 4X4 is working? Is it just by the dash light, or are you losing traction in the front?
Old 03-11-2014, 05:18 PM
90pioneer's Avatar
90pioneer
90pioneer is offline
I have the exact same issue in my 03 F250. Started happening a couple months ago. 4x4 would work intermittently, losing traction in the front.
I've been running with my hubs manually locked for the time being and have no more 4x4 issues so I believe it to be a vacuum leak. I plan to track it down this summer.
Old 03-13-2014, 02:55 PM
Dan V's Avatar
Dan V
Dan V is offline
Got mine fixed! Crappy Dorman o-ring.
I locally sourced some -152 Buna-n o-rings....$2.51 for both Swapped them with the Dorman....4x4 again baby!
I measured the diameter of the new o-ring, .102, right as it should be, against the Dorman that's been in for a year. .092. I knew something was up when the locking hub was pretty easy to remove from the hub. When I installed the new, I had to tap them in with a dead blow.
Old 03-13-2014, 02:58 PM
HKusp's Avatar
HKusp
HKusp is offline
Interesting what you will find when playing around with these trucks and the aftermarket, isn't it?
Old 03-13-2014, 04:22 PM
Dan V's Avatar
Dan V
Dan V is offline
But come on man....how hard should that be? It's an o-ring for crying out loud. But I suppose if you make a product with 10% less (or more) material, you can get some profitability.
Old 03-13-2014, 04:35 PM
HKusp's Avatar
HKusp
HKusp is offline
How much could that save them, 100 dollars per 100,000 units?
It's just stupid.
Old 03-13-2014, 09:44 PM
t.scottNDU's Avatar
t.scottNDU
t.scottNDU is offline
The MityVac has been a rather expensive but useful investment for me. It can be used for a slew of things
Old 03-14-2014, 06:50 AM
Dan V's Avatar
Dan V
Dan V is offline
The ginormous picture of the one I bought was around $30 on sale @ Harbor Freight.....took almost 2 weeks for it to arrive though.
bubbajoe1960
1999 to 2016 Super Duty
09-12-2018 10:33 PM
Troy_455
07-13-2015 08:37 AM
gofast51004
01-20-2011 06:16 AM
rbrad6937
02-24-2010 09:57 PM
harstad23
12-15-2007 11:25 PM
Quick Reply: 02 f250 4x4 issue
