1988 Fuel System Dual Function Reservoir Problems
I have a 1988 F-150 4.9L 5-speed 2x4. The truck originally had dual tanks. Both tanks rusted from the inside. Last year I replaced the rear tank, tank pump, and sending unit. I removed the front tank and am not replacing. I also replaced the high pressure frame pump and frame mounted fuel filter.
Truck ran great for the past year.
Last week fuel began leaking out of the fuel lines for the front tank (they were left connected to the Dual-Function Reservoir and the tank side end was wrapped in plastic and tied up under the bed.) I removed these lines and blocked off the two ports on the Dual Function Reservoir that fed the front tank (which is no longer installed).
Yesterday, the truck was running great, then died instantly while driving. I could not restart it and had to get a tow. An hour or so later (after being towed home), the truck started and ran, however the high pressure frame pump is moaning pretty loudly.
My questions are:
Can I replace the Dual-Function Reservoir with a Single-Function Reservoir? Is the Single-Function Reservoir a direct replacement (bolt holes, fuel line connections, etc.)?
Can I remove the Dual-Function Reservoir and put these lines in place of a reservoir? Dorman Products - 800-159 or is it better to keep a reservoir in place for the pressure frame pump?
Thanks!
My questions are:
Thanks!
"SUBFORD", thanks for the response!
Is this the correct Single-Function Reservoir?
P/N: FOTZ9K044A
Thanks!
P/N: FOTZ9K044A
Thanks!
Being that the Dual-Function Reservoir is 26 years old plus the fact that I am only running a single tank, I just assume replace it with a Single-Function Reservoir. I will definitely hold onto the DFR after removing it, and will open it up to inspect as well.
You should be fine with the SFR but do tear into the DFR and see how they work, It's a neat idea but a pi*s-poor design!
Thanks again for the help "subford". The Single-Function Reservoir bolted right up without any issue. I also replaced my frame pump and inline filter. Truck is running great now.
Mine ran 23 years 363 days (according to the build date) before it plugged up and that happened just after a very rough ride in a near-miss accident. I had to take the ditch to avoid a crash with other vehicles that had crashed in the road. No damage was done to my truck but I guess the ride shook loose the gunk in the tanks. I had to have fuel pumps shortly after the plugged filter discovery.
flowney
01-05-2018 12:40 PM
Dlasure2
02-09-2011 05:19 AM
rickster53
01-22-2011 08:22 PM
