6.9L and C6: What color modulator to use?
I was seeing if anyone had an opinion about which "color" transmission modulator to buy for a 1984 4x4 6.9L C6. I can't shift out of first, and the modulator is stock, so it probably could use replacing either way and I'm starting there on fixing this problem. Thanks for sharing any experience with different colors.
I got a lot done yesterday with the transmission. I had the oil pan off, while I had that off I put in a drain plug and replaced the screen. It definitely needed a new gasket also. I then filled it up with fresh ATF. The pan looked pretty good inside and wasn't too dirty.
I took the old modulator out and did the vacuum test on the VRV, and it needed adjustment but held vacuum. I also vacuum checked the line between the VRV and modulator, and it held vacuum. There was dirty ATF in the line at the modulator end on the vacuum hose, so it was probably the modulator that was bad, in conjunction with the VRV needing adjustment. It now has a new (green) modulator . I didn't get to road test it because it needs an alignment, but I'm crossing my fingers that it will shift nicely. Thanks again for the help.
LittleBlue79
09-05-2017 09:17 PM
Chris Ko
05-13-2017 10:23 PM
89GTAWS6
08-13-2013 06:45 PM
wreckinball
03-23-2011 01:11 PM
