Alternate to tailgate chains, what did you use?
Old 03-10-2014, 06:36 PM
drptop70ss's Avatar
drptop70ss
drptop70ss is offline
New scratch built truck bed is moving along and I have to decide what to use for the tail gate hardware. I will be using the factory style stainless lower hinge mounts but cant decide to stick with chains or something else the gate up top.
What have you guys used to clean up the look of the top of the gate?
Old 03-10-2014, 07:11 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
I used those rubber coated cables for a '90's S-10 pickup.
Some pics in my tailgate build thread...
https://www.ford-trucks.com/forums/1...asy-steps.html
Old 03-10-2014, 07:16 PM
49willard's Avatar
49willard
49willard is offline
I also used the coated cables and marine latches from Rods Trucks
Old 03-10-2014, 09:33 PM
ryans88gt's Avatar
ryans88gt
ryans88gt is offline
where did you get the hardware that the cables connect to? I have the same latches and was thinking about the cables, but didn't know what to attach to?
Old 03-10-2014, 09:56 PM
49willard's Avatar
49willard
The special bolt that is on the truck bed came from a junkyard, Ford Truck. I made the reinforcing brackets and plates that are on the outer surface of the tailgate and on the outer surface of the bed to accept/spread the load or weight on the tailgate.
Unfortunately it is difficult to see the brackets and plates in the only other photos that I have since they are body colored. The whole idea however was to make the reinforcements disappear. The plates are made out of 1/8' stock with 90 degree bends for added strength. The reinforcements are not welded to the bed or tailgate.
When positioning the marine clasps you want the latch to come over center so that it will not inadvertently pop open on a bumpy road. It is touchy to get them just right.
Edit: I should add that the right angle mount on the inside of the tailgate that the bed end of the cable is attached to is a piece of 1/4" SS bent at 90 degrees.
In short all brackets I fabricated.
Your bracket will be slightly different since mine is a 49 bed/tailgate.
Old 03-10-2014, 10:27 PM
ben73058's Avatar
ben73058
ben73058 is offline
Hey Dave,
Here is a thread from a while back where Drewski & others outline
different approaches.
https://www.ford-trucks.com/forums/9...latch-kit.html
Ben in Austin
1950 F1
Old 03-10-2014, 10:56 PM
smallello's Avatar
smallello
smallello is offline
I used F-150 cables for mine with seat belt buckle latches.
Old 03-11-2014, 07:39 AM
48 Steel's Avatar
48 Steel
48 Steel is offline
A couple of us here used seat belt latches. Bolted or welded they hold the tailgate secure.
___________________________________________
48 Ford F1 - Darkside
46 Ford Tudor - Street Rod
"Happiness - 3 pedals and a 5 speed"
Old 03-11-2014, 08:55 AM
Drewski 2's Avatar
Drewski 2
Drewski 2 is offline
I fabricated folding straps out of scraps of stainless to go along with my redneck buckle latches. My initial mockup was done with wood strips. After I got all the details worked out, I polished the straps and assembled with polished stainless bolts and locknuts.
Old 03-11-2014, 09:01 AM
ZSK's Avatar
ZSK
ZSK is offline
Some great solutions in here.
Old 03-12-2014, 04:17 PM
rhopper's Avatar
rhopper
rhopper is offline
Dave, my latches are home made. Tapered steel rod inside the top roll with springs behind it. For chains, I used standard hardware store chain, inside the bed, with clear plastic tubing over it. You can sit on the tailgate without fear of breaking the chains. Not as fancy as some, it was inexpensive and looks OK.
Old 03-12-2014, 10:01 PM
Giesterfarher™'s Avatar
Giesterfarher™
Giesterfarher™ is offline
Aw hell. That's just slicker than runny boogers.
I know how I'm doing my tailgate straps and latch now.
Old 07-06-2017, 02:18 AM
fordslut's Avatar
fordslut
fordslut is offline
a lot of missing pictures.
Old 07-06-2017, 05:05 PM
Drewski 2's Avatar
Drewski 2
My pictures are missing thanks to Photobucket holding them ransom.
mrf-100
29
06-10-2018 05:30 PM
Stepney
04-01-2018 02:58 PM
Redneck1465
Ford Truck Parts for Sale
20
09-30-2012 04:57 AM
edgexcrider
Paint & Bodywork
09-27-2004 03:13 PM
Jag Red 54
04-30-2003 05:16 PM
Quick Reply: Alternate to tailgate chains, what did you use?
