51 F1 hood hinges welded to cab? - Ford Truck Enthusiasts Forums
Old 03-10-2014, 06:30 PM
drptop70ss's Avatar
drptop70ss drptop70ss is offline
drptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to behold
Going over stuff on the cab and found my drivers side hood hinge is tack welded to the cab. Factory or farmer?
Also are the 3 studs supposed to have nuts on the inside of the cab? I would think so but both sides of my cab have a nut only on the one stud? I want to take these off to clean up, should they just come off after the nuts are off and the welds cleaned off? More strange stuff on this truck.
Old 03-10-2014, 06:43 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Well, that's one way to keep them in adjustment! Should be nuts and washers on all the studs, no welds.
Old 03-10-2014, 06:49 PM
drptop70ss's Avatar
OK so farmer fix it is. Welds will come off and will go back to factory.
Old 03-10-2014, 10:57 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
If your hood is aligned where the hinges are, be sure to mark them so you can put them back in the same place with minimal hassle.
Old 03-11-2014, 10:28 AM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
I see at least two studs partially broken off. If you need a set in better condition, I have several.
Old 03-11-2014, 06:34 PM
drptop70ss's Avatar
Thanks I will check out the condition once I get them off.
Old 03-11-2014, 06:47 PM
pineconeford's Avatar
pineconeford pineconeford is offline
pineconeford is a splendid one to beholdpineconeford is a splendid one to beholdpineconeford is a splendid one to beholdpineconeford is a splendid one to beholdpineconeford is a splendid one to beholdpineconeford is a splendid one to beholdpineconeford is a splendid one to beholdpineconeford is a splendid one to behold
"Factory or Farmer" would make a good name for a Quiz Show.
Tom
Old 03-12-2014, 04:21 PM
rhopper's Avatar
rhopper rhopper is offline
rhopper has a good reputation on FTE.rhopper has a good reputation on FTE.
Tom, that would be a great game to play with our trucks. Factory or Farmer.
Lets do it again! 1951 Ford F1 LT1 supercharged, 4L80E, EFI, jag IFS, etc.. drptop70ss 1948 - 1956 F1, F100 & Larger F-Series Trucks 420 11-09-2016 09:41 PM
F1 latch repairs, fix the sag and make them work! drptop70ss 1948 - 1956 F1, F100 & Larger F-Series Trucks 35 11-05-2015 08:43 PM
LED replacement bulb info, dont bother with them drptop70ss 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 08-19-2015 05:40 PM
1951 radiator support sheetmetal pieces, mounting question drptop70ss 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 07-27-2015 03:00 PM
1954 panel truck for sale on CL..oh boy! drptop70ss 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 04-17-2014 11:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
