Loose steering - complete front end rebuild - Ford Truck Enthusiasts Forums
Old 03-10-2014, 06:48 PM
ontarioford ontarioford is offline
ontarioford is starting off with a positive reputation.
2005 F350 6.0 Ė 212,000 km
<o></o>
Hey Guys, I took my wifeís F350 in today. I noticed thesteering seems to be getting worse over the last few months and yesterday shetold me she felt a rubbing when she turns. The truck also has had a funny pulsewhen turning. If you sit in the driveway and move the steering left and rightan inch or so it feels like it is moving over center. Hard to describe but itkind of feels like the power steering is pulsing. Also, the steering box isleaking.
Took the truck in today and ford tells me that I need
A new steering box,
New ball joints
New pitman arm
Alignment
There were a few other items as well but I cannot remember exactly.
They tell me the bill is going to be around 3500. I am mechanical and normally do my own workbut I donít have the tools or time for this type of job.
Does this seem reasonable? Does this amount of wear seem consistentwith the mileage or do you think they are just going to replace everything to ensurethey fix the issue?
Old 03-10-2014, 07:42 PM
Rocketgs Rocketgs is offline
Rocketgs is starting off with a positive reputation.
Most of what is listed seems realistic to me for replacement timing. The price is probably realistic by dealer standards. In my area I would expect to pay a good non-dealer shop around $2500 based on work I had done just under 2 years ago.
Old 03-11-2014, 05:46 AM
bodywerks bodywerks is offline
bodywerks is starting off with a positive reputation.
Steering gear and pitman arm together is max, $500. You can borrow a pitman arm puller for free from autozone. The steering box is held in by three easily accessed bolts and a couple hoses basically. It can be done by the shadetree pretty easily.
A dealer will use OEM ball joints, that's like $80 total, plus lets say another $100-120 in seals. So basically they want about $2700 in labor for ball joints and a steering box???
Yeah, ball joints are a little more involved, but still straight forward and I say they, too can be done by the shadetree. But just to give you an idea, a reputably tire/alignment shop quoted me $730 for Moog balljoints installed and alignment. I think that included seals in the hub as well.
My advice - if you don't want to do it yourself then shop around. IMO, parts and labor for a quality job like that shouldn't be more than $2,000-2300.
Or
Do the steering gear yourself, limp it to a reputable tire/alignment shop that you get a quote from, and have them do the ball joints. All in all you'd be out no more than $1300-1400.
Or, give it a go yourself for about $750 in parts and the cost of an alignment job.
Old 03-11-2014, 07:25 AM
exiled's Avatar
exiled exiled is offline
exiled has a very good reputation on FTE.exiled has a very good reputation on FTE.exiled has a very good reputation on FTE.
It surprises me that they didn't mention the sway bar end links.
I don't know if the quote is unreasonable, but it sounds a lot more than I would be willing to give. Moog ball joints and seals, moog end links, moog pitman arm, and a good ball joint press will run $700.
I couldn't pay $2500 for the labor personally.
Old 03-11-2014, 08:28 AM
DerbyPowerstroke DerbyPowerstroke is offline
DerbyPowerstroke is gaining momentum as a positive member of FTE.
Ball joints are not as hard as it sounds. You can also borrow the press kit and with an impact gun it makes popping them out pretty easy. You can do it with a wrench but it's just a little more elbow grease. To me, it sounds like a lot of coin, if I could do it myself I would.
Old 03-11-2014, 09:14 AM
mustang_309's Avatar
mustang_309 mustang_309 is offline
mustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to behold
For 3500 bucks you could buy a bunch of tools and if you are mechanically inclined its not that bad of a job. The local ford shop wanted 600 bucks to install an idler arm and pitman on my 03 F-150 4X4 ( that included the parts ) and even that bill was enough to motivate me to do it myself.
Old 03-11-2014, 10:47 AM
mhoefer's Avatar
mhoefer mhoefer is offline
mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.
The OP is in Canada and those prices are more like what i have experienced. Ball joints, hub seals, alignment cost me $1250 several years ago. Labour rates are also much higher in Canada. Upside, great mens and women's hockey teams. GO CANADA! For what its worth, thats not a terrible price, but you could do parts of it yourself amd have them do the ball joints, to save you some labour.
Old 03-11-2014, 12:01 PM
Carolina Rig's Avatar
Carolina Rig Carolina Rig is offline
Carolina Rig is gaining momentum as a positive member of FTE.Carolina Rig is gaining momentum as a positive member of FTE.
Quote:
I've always heard that if the opportunity presents itself, a trip to the Canadian Ballet is fun and entertaining.
Old 03-11-2014, 02:17 PM
Dlinzy Dlinzy is offline
Dlinzy is starting off with a positive reputation.
From Experience... the Pitman Am Puller from anywhere other than Caterpillar Dealer wont fit over the Super Duty version. I had to cut mine off with a cutoff 90 degree grinder and 3.5" wheels.
d
Old 03-11-2014, 03:27 PM
Misky6.0's Avatar
Misky6.0 Misky6.0 is online now
Misky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputation
Quote:
d
I got a puller from harbor freight, had to work to get it on but it did the job for my Excursion. I used a 4' breaker bar to get enough force and then a gentle tap with a hammer it popped off with a loud 'pow'
I would consider upgrading to a redhead steering box - IF you plan to keep it. Light years better than stock - but $$$ too.
Old 04-02-2014, 11:24 AM
I wanted to provide an update: Since I have owned this truck I have experienced an odd pulse going around corners. It is kind of hard to explain but it felt like the wheel would not sit at top dead center and that the wheel would rock back and forth over the top while going around long bends in the road. My father said it felt like it was stuck in four wheel drive. It was unnerving when hauling my 15,000 plus pound boat and I swore this year it had gotten to the point that I did not think I would haul it at all.
Turned out to be the steering box, I guess it was bleeding back and forth causing the pulsing. They changed the box last week and the truck feels like the 911. What a difference it is amazing. I bought the truck with about 90k on it and it has been doing that since we owned it.
IPR Oil/EGR Cooler and Coolant Filter on My 2005 Excursion Excurvelle 6.0L Power Stroke Diesel 10 02-16-2015 09:18 PM
New owners of old truck seeking knowledge! jcstepmom28 1987 - 1996 F150 & Larger F-Series Trucks 6 11-21-2014 05:16 PM
Custom Gauges PA F250 1973 - 1979 F-100 & Larger F-Series Trucks 17 08-28-2013 07:35 AM
BURN IT TO THE GROUND cbr600rx7 1994.5 - 1997 7.3L Power Stroke Diesel 47 01-30-2013 06:48 PM
wuddya guys think? FFemt5287 1994.5 - 1997 7.3L Power Stroke Diesel 11 01-02-2009 01:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
