Transmission Temperature - Ford Truck Enthusiasts Forums
Old 03-10-2014, 06:27 PM
StanleyZ's Avatar
StanleyZ StanleyZ is offline
StanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to behold
My tranny temp seems to be a good bit higher than either of my previous trucks. I haven't towed yet but the temp was showing 205 degrees today during a routine unloaded trip. Is that normal?
Old 03-10-2014, 07:01 PM
rtazz17's Avatar
rtazz17 rtazz17 is offline
rtazz17 has a good reputation on FTE.rtazz17 has a good reputation on FTE.rtazz17 has a good reputation on FTE.
Cant say for sure but I believe in the summer in temps in the 90s towing my 14k fiver my trans temp was max 205-210.Ill have to keep an eye on my edge cts tomorrow to see what my unloaded temp is but I THINK its less then 205.Just noticed yours is a dually so maybe it runs slightly hotter then my srw.
Old 03-10-2014, 07:15 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
I seem to run right around 200-205 as well. Trans cooler is cooled with the coolant.
Not in front of the radiator with air on this one.
Old 03-10-2014, 07:18 PM
ruschejj's Avatar
ruschejj ruschejj is offline
ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.
My 2011 F250 seems to settle between 192 and 201.
I've never seen temps as high as yours but my truck is a bit smaller than yours.
Old 03-10-2014, 07:45 PM
Jim5x5 Jim5x5 is offline
Jim5x5 is starting off with a positive reputation.
2013 F350. Mines usually in the mid to high 190's without towing or hauling anything. That's been in chicagoland with these nice warm days in the low teens.
Old 03-10-2014, 09:05 PM
T diesel T diesel is offline
T diesel has a good reputation on FTE.T diesel has a good reputation on FTE.
Normal.
Old 03-10-2014, 10:05 PM
Dim Sum's Avatar
Dim Sum Dim Sum is offline
Dim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant future
Normal. Oil is cooled via the larger coolant loop which runs in that range.
Old 03-11-2014, 08:40 AM
Gearitis Gearitis is offline
Gearitis is gaining momentum as a positive member of FTE.Gearitis is gaining momentum as a positive member of FTE.
My normal oil temp, unloaded, runs 195-201, I am out camping right now and just pulled my 10k 5er about 250 miles, ambient temp was 65, and the TFT stayed in the 205-214 range depending on the hills pulled. I have seen TFT's unloaded on I-35 unloaded with ambient at 70 running in the 205 range when running about an hour or a bit more, I never thought to much about.
Old 03-11-2014, 09:26 AM
StanleyZ's Avatar
Thank y'all. I'm in fort myers and it was low 80s yesterday. Wonder what it's going up to when I pull Mount Eagle Tn or some of the passes out west next summer. My 7.3L and 6.4L stayed around 170 even towing except for hard pulls when they would get to 195 or a little more.
Old 03-11-2014, 09:47 AM
senix's Avatar
good question on the summer temps. I did a run out to western MD back in Sept but didn't know how to monitor that. Lots of grades there all the way to OH.
Might be doing another Ohio meet soon so I might find out then.
Old 03-11-2014, 10:13 AM
Tom's Avatar
Tom Tom is offline
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Quote:
You will have no trouble up Monteagle. The transmission has a thermostat which maintains temperature just like your engine. As tranny temps get hot the thermostat opens and provides more cooling to the transmission.
I'd be surprised if you saw 220 pulling your trailer up that grade.
Old 03-11-2014, 10:24 AM
StanleyZ's Avatar
That's good to hear as I'm pretty sure I blew a HG there the last time I went over.
Old 03-11-2014, 11:22 AM
Troy Buenger's Avatar
Troy Buenger Troy Buenger is offline
Troy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to behold
In addition to what others have said the tranny fluid is synthetic and is rated to go 150k miles before an oil change with these new transmissions.
Old 03-11-2014, 11:19 PM
StanleyZ's Avatar
Quote:
Thanks, I haven't gotten that far in the manual yet. Still trying to figure out the voice thing.
Old 03-11-2014, 11:27 PM
scar100's Avatar
scar100 scar100 is offline
scar100 is starting off with a positive reputation.
This is good to know. I was thinking of having mine done soon. Will wait a bit.
Are my temps high? cory5517 6.0L Power Stroke Diesel 10 05-25-2016 11:20 PM
Coolant Temp and Oil Temp Delta Towzilla 6.0L Power Stroke Diesel 16 05-26-2014 08:25 AM
coolant temp sensor 351WFormerPlowTruck 1987 - 1996 F150 & Larger F-Series Trucks 0 06-19-2013 08:58 AM
EOT VS EWT Ford are best 6.0L Power Stroke Diesel 19 05-06-2013 09:16 AM
Oil Temp vs Water Temp Guage bkcowboss 1994.5 - 1997 7.3L Power Stroke Diesel 15 01-26-2008 04:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
