Questions about driveshafts :) - Ford Truck Enthusiasts Forums
Old 03-10-2014, 03:04 PM
ex3em's Avatar
ex3em ex3em is offline
ex3em is starting off with a positive reputation.
Hi
I got Ford f-100 1974 stepside with 302efi engien AOD tans.
My driveshaft is damaged cannot be repaired.
Wondering if i can use for example a 1983-2010 Ford Ranger driveshaft ?
Or if there is some other joint that will fit ?
impossible for me to get hold of an original, because I live in Sweden.
hoping for a quick answer
Best regards from Sweden / Ex3em
Old 03-10-2014, 03:46 PM
trozei's Avatar
trozei trozei is offline
trozei has a great reputation on FTE.trozei has a great reputation on FTE.trozei has a great reputation on FTE.trozei has a great reputation on FTE.trozei has a great reputation on FTE.
Do you have a local driveline shop? They can usually adapt or even make you a driveshaft.
Old 03-10-2014, 04:19 PM
ex3em's Avatar
I'm trying to find the one that has the same joints, so that I can adapt it to the car.
driveline shop is very expensive here.
Old 03-10-2014, 04:32 PM
77&79F250's Avatar
77&79F250 77&79F250 is offline
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
Quote:
Originally Posted by ex3em View Post
Hi
Did you twist the u joint cap eyes off? Its not that impossible to get, so you need a d/s for a 1974 F100 shortbed, 302 w/EFI, swap in or add on? AOD trans was swapped in too right? So will a stock one fit length wise?
What are your old d/s ones measurements, I mail parts to other FTE members to Sweden and Norway.
Old 03-10-2014, 04:40 PM
ex3em's Avatar
drove off the road and driveshaft was bent after that, and the driveshaft is shortened 3cm after all modifications
nothing else was damaged, efi from a Eco 150xl
Stock wont fit
Old 03-10-2014, 04:57 PM
ex3em's Avatar
'll Check the old measurements, can't remember right now
How much is the fee for transport to sweden ? got a low budget, atm
Old 03-10-2014, 05:23 PM
redroad's Avatar
redroad redroad is offline
redroad has a good reputation on FTE.redroad has a good reputation on FTE.
The AOD trans was not ever offered in your truck so the driveshaft is not stock .. Replacing the tube should not be that much
Old 03-10-2014, 05:40 PM
ex3em's Avatar
Quote:
No the D/s it is modified to fit, here it costs around 668,38 US and thats without joints and the distance i need to travel to deliver the D/s
Old 03-10-2014, 05:44 PM
ex3em's Avatar
all I really want to know, if there's any other car That uses the same joint that my car has ?
Old 03-10-2014, 06:37 PM
GLR's Avatar
GLR GLR is online now
GLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputation
If the trans is an AOD not an AODE the front DS yoke from a 81 crown vic, grand marguis to 1991 will work. The rear will have to be modified to fit the 9" (if that's what you have) pinion yoke.
An AODE might work but, I'm not near my stash right now so I can't check.
Old 03-10-2014, 06:41 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
99.999% sure no other car uses your set up.
Especially not a '83-'10 Ranger.
Old 03-11-2014, 10:06 AM
ex3em's Avatar
Trans: PKB N7T
066375 E31
E7UP BB
Old 03-11-2014, 10:30 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Trans: PKB N7T / 066375 E31 / E7UP BB
1987 E150 302 AOD.
AOD introduced in 1980 LTD/Grand Marquis/Lincoln Town Car/Continental Mark VI/Thunderbird/Cougar 302, introduced in 1981 F100/150 302.
1974 F100: 240/300 I-6 & 302 = C4 ~ 360/390/460 = C6.
Old 03-11-2014, 11:38 AM
ex3em's Avatar
right now using the original D / S it has been shortened with a few cm. U-joints size is 82x27mm. is there any other car that has the same size on their D / S, the modification of the D / S, I can fix myself with tig and pipe
Old 03-11-2014, 11:19 PM
redroad's Avatar
Can't you cut off the 2 ends being careful only to cut the tube .. then carefully grind/cut the remaining tube from the ends and then reuse ? or are they damaged also ?
kilometer per hour scale for F100 -73 in Sweden... Ford3901973 WTB - Parts & other 4 08-26-2015 03:02 PM
Wrong region on my roof dvd. LinusHell Excursion - King of SUVs 4 06-07-2015 08:52 PM
Hello from Sweden MagnusB New Member Introductions 8 12-26-2014 06:03 AM
OIL winter F150 2006 SwedMartin Oil & Lubrication 2 08-19-2014 10:51 AM
New intake f100swe Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 3 07-08-2014 02:58 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
