Got a new project. It's part everything. Got to love AMC
Moved the shackles to the rear of the springs, put a different front drive shaft on that I had layin around that was luckily the right size/length. Bought a regular set of perches, hogged the driver side out, trimmed off part of pumpkin, and put bigger diameter u bolts on. Put longer shock on, moved the brake line tabs down. The steering at the pitman arm had just enough flex in it to not bind at full drop.
Got it all done. Need new shocks for the rear, and a drop pitman arm to keep bump steer to a min. The rear you can see the brackets I made to relocate the front of the springs. The back, I cut out the bottom of the hanger and stuck the shackle in from the bottom. But I'm going to have to redo that, the shackle angle is not where I'd like it to be. It ended up being 7 inches of lift.
Here's a shot compared to the ex.
Received 3,101 Likes
on
