Got a new project. It's part everything. Got to love AMC
08-25-2014, 12:56 PM
Hopefully not! I figure if I keep 33s on here, it should hold up well. Should....
08-25-2014, 01:39 PM
I can't see why it wouldn't, but anything can happen if you're willing to push it to its limits.
08-25-2014, 02:10 PM
Well if you saw the rig this engine came out of, you'd know usually I push the limits....
08-25-2014, 04:19 PM
Quote:
Originally Posted by
hav24wheel
Well if you saw the rig this engine came out of, you'd know usually I push the limits over the edge of very high cliffs.....
fixed it for ya Dave.
08-25-2014, 05:44 PM
Lmao. That might be closer to the truth
08-25-2014, 05:53 PM
remember, i have seen the videos of your antics with that rig.
08-25-2014, 06:53 PM
Ya, there a few that might raise some suspicion of abuse.
08-25-2014, 08:09 PM
hav24wheel
I've been around for a while, just not a real regular fte'er, or any other forums for that matter.
White 90's crew on late 70's chassis 44" pitbulls
08-25-2014, 09:01 PM
Lol, yes sir, that's the animal. It had D60 locked with 35 spline outers, 10.25 rear welded and a 203/205 doubler tripple sticked.
08-26-2014, 09:55 PM
Got some more progress on the Jeep.
Modded the Ford 205 to run upside down, had to redrill two mounting holes to get it to bolt up. Tapped 4 holes to put pipe plugs in instead of the rubber plugs that where in it. Made a bracket for my shift cables... To make them work, I had to cut down the detent spring so make the shift rails move easier.
08-26-2014, 10:58 PM
Nice! I haven't seen one flipped before. Got plans for a T.C. mount?
I've twinsticked ford/chevy/dodge ...I've seen both the rubber plugs and metal plugs (think tiny freeze plug) from all 3.
08-27-2014, 05:54 AM
In fact I do have plans for that mount. I'm going to run some heavy flat stock forward, and put a rubber mount off the crossmember.
08-27-2014, 09:39 PM
Got exhaust done. Forgot to take a pic. It's a ft of 3 inch pipe, a 18 inch glasspack, with 4 inch pipe coming off it with a turn down. One of them on each header.
<iframe width="420" height="315" src="//www.youtube.com/embed/KRBMR9N2QHU" frameborder="0" allowfullscreen></iframe>
08-28-2014, 11:02 AM
Sounds good! But I think your tach is faulty.....cause 351m's ain't supposed be anywhere near 6500rpm! lol
08-28-2014, 11:34 AM
I know the tach is right. It's not suppose to maybe, but I don't do thing the normal/right way!
I did a little work to make that thing run like that. Heads shaved, big cam, matching springs, main cap studs and a few other things. But crank and rods are all stock.
