05 Expedition blows hot air through defrost vents when set in max a/c mode - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 03-10-2014, 11:29 AM
jbedsole23 jbedsole23 is offline
jbedsole23 is starting off with a positive reputation.
My 05 Expedition is giving me some trouble. When I turn the a/c on it blows hot air through the defrost vents no matter what I do. I used to have a thumping noise coming from the dash but that stopped. Any help with this would be great.
Old 03-10-2014, 12:09 PM
alwaysfords41's Avatar
alwaysfords41 alwaysfords41 is offline
alwaysfords41 is gaining momentum as a positive member of FTE.
I'd guess you have two problems. The temperature problem is a broken blend door and the defrost location for the air flow is what happens when you have a vacuum leak - it is the default. The blend door is in the dash and can be fixed by removing the dash, or by using Heater Treater through the back of the glove compartment. The vacuum leak is likely in the area of the battery tray as the lines go through that area and are prone to corrosion.
Old 03-10-2014, 12:59 PM
I have never heard of heater treater. How exactly would I use that?
Old 03-10-2014, 06:50 PM
It is a metal blend door, they make versions for lots of cars. Heatertreater.com
Old 03-11-2014, 07:25 AM
I saw that on the internet. I was looking around the battery area last night and saw multiple spots in the vacuum lines that could be the issue. Do you have any idea on what size the vacuum hose is? Some spots it appears to be large tubing and other spots it is very thin. Not sure how to match that up when it goes into the "T".
2005 Exp not blowing air NottiAlaska Expedition & Navigator 4 10-07-2016 06:31 AM
in 4wd the a/c blows out the defroster vent?? pickupman2002 6.0L Power Stroke Diesel 21 09-24-2012 03:37 PM
2005 Expedition automatic a/c random switch totalblue Expedition & Navigator 2 10-03-2011 07:35 AM
E-350 rv A/C question MDSLIGHT Cooling, Heating, Ventilation & A/C 3 07-28-2011 07:16 AM
A/c blowing through defrost vents 300FOREVER Ranger & B-Series 5 08-03-2010 08:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
