05 Escape oil leak fix or not? - Ford Truck Enthusiasts Forums
Old 03-10-2014, 08:56 AM
gerry2222 gerry2222 is offline
gerry2222 is starting off with a positive reputation.
Just joined.
Have quick question on my 05 Escape 3.0L. Very small leak bottom of timing chain cover. Cleaned, drove 600 miles, oil level fine.
Am I OK with just checking it. Thanks
******** charset="UTF-8" src="chrome://hdv/content/hdv.js" type="application/javascript">*********>
Old 03-18-2014, 12:59 AM
ajwgator ajwgator is offline
ajwgator is starting off with a positive reputation.
I would just keep an eye on it a bit longer, say a couple of oil change cycles and see if its really that bad. If could have been spilled from an oil change some time in the past. JMO
Old 05-19-2014, 09:43 PM
PettitWC's Avatar
PettitWC PettitWC is offline
PettitWC is starting off with a positive reputation.
Quote:
Ditto!
I think I have the same issue on mine, but I need to work myself up want to go back in for some more. I just did the oil pan gasket and it'll need a valve cover gasket soon too, but the front crankshaft seal and timing cover gaskets are high on the list.
Engine swap question. re: Year Differences lupuseven 6.0L Power Stroke Diesel 9 06-20-2014 07:22 PM
Opinions on getting upgrade work done while in shop lupuseven 6.0L Power Stroke Diesel 12 05-29-2014 07:10 PM
Questioning Codes given. lupuseven 6.0L Power Stroke Diesel 0 05-05-2014 11:37 PM
HPO system Part #'s? lupuseven 6.0L Power Stroke Diesel 6 01-25-2014 11:03 PM
05 Escape 2.3L L4 DOHC Check Engine Code.... GRNMSTR Escape & Escape Hybrid 1 10-09-2011 07:42 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
