Headlight Switch
Headlight Switch
My head lights stopped working last night on my 1978 F350 (140" WB) with the 460 CI. I replaced the dimmer switch on the floor & that didn't fix it. Picked up a new head light switch and easily removed the switch ****. But I can't figure out how to remove the switch from behind the dash. I can get my hand up under the dash & grab hold of the switch but any suggestions on how to remove it? Thanks!
What he said for the headlight switch.
Use a small flat tip screwdriver push the lock tab on the back side of the wiper switch **** itself to get it off the shaft. The wiper switch shaft stays in the switch.
Once the bash bezel is off you will see the lock nut (pt#11650) for the headlight switch, its easy.
The nut for the headlight switch is a funny one too. it's like a weird spanner nut, you either need a really wide flathead screwdriver, or take a smaller one and tap it around in a circle until it's loose. Honestly a putty knife used as a screw driver doesn't sound far fetched for the idea.
Then again though that was the factory switch (motorcraft one not "el cheapo" replacement), who says the damn PO didn't put that shallow nut on there...
SeaCarr
10-21-2013 02:16 PM
Customlover
11-05-2008 06:17 PM
Caleb1
15
05-13-2008 03:18 AM
scrapyardking
03-27-2008 04:45 AM
