Tranny problem HELP!!!
Old 03-09-2014, 06:11 PM
Jake_f16's Avatar
Jake_f16
Jake_f16 is offline
Today I took off from a stop sign and the yoke going into the rear end broke. My driveshaft then fell out and was spinning and flopping around under the truck so I put it in neutral and it continued to spin in gear. shouldn't the tranny go into neutral even with the driveshaft unhooked from the rear end.
Old 03-09-2014, 06:14 PM
Jake_f16's Avatar
Jake_f16
Jake_f16 is offline
Sorry I forgot to mention it is a 2001 F250 7.3l and it does have a shift kit from the previous owner but I am not sure what one is in it.
Old 03-09-2014, 07:04 PM
mueckster's Avatar
mueckster
mueckster is offline
Without the load imposed by coupling of the driveshaft to the differential, the output can still rotate. Placing it in Park would be the only way to mechanically stop it.
Old 03-09-2014, 07:50 PM
Jake_f16's Avatar
Jake_f16
Jake_f16 is offline
Mueckster,
I was kind of thinking the same thing just wasn't sure. I tried to shift into park and it was grinding the gears so I just left it and shut the truck off.
Old 03-09-2014, 08:54 PM
Scerb's Avatar
Scerb
Scerb is offline
Grinding was likely because of what Muekster said. Same effect as trying to go into park while the truck is moving. Assuming nothing got damaged, it probably shifted into park when you shut the motor off.
Old 03-10-2014, 08:43 AM
Jake_f16's Avatar
Jake_f16
Jake_f16 is offline
Thanks guys for the info it is much appreciated.
StanleyZ
6.4L Power Stroke Diesel
13
06-05-2013 08:17 PM
rockhound7777
1999 to 2016 Super Duty
04-28-2010 07:50 PM
YenahsYenzow
07-05-2008 09:50 PM
greybullit
1978 - 1996 Big Bronco
31
02-10-2006 08:45 PM
mybigredford
05-07-2004 06:02 PM
Quick Reply: Tranny problem HELP!!!
