Tranny problem HELP!!! - Ford Truck Enthusiasts Forums
Old 03-09-2014, 07:11 PM
Jake_f16's Avatar
Jake_f16 Jake_f16 is offline
Jake_f16 is starting off with a positive reputation.
Today I took off from a stop sign and the yoke going into the rear end broke. My driveshaft then fell out and was spinning and flopping around under the truck so I put it in neutral and it continued to spin in gear. shouldn't the tranny go into neutral even with the driveshaft unhooked from the rear end.
Old 03-09-2014, 07:14 PM
Jake_f16's Avatar
Sorry I forgot to mention it is a 2001 F250 7.3l and it does have a shift kit from the previous owner but I am not sure what one is in it.
Old 03-09-2014, 08:04 PM
mueckster's Avatar
mueckster mueckster is offline
aka Redneck Wrencher
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
Quote:
Without the load imposed by coupling of the driveshaft to the differential, the output can still rotate. Placing it in Park would be the only way to mechanically stop it.
Old 03-09-2014, 08:50 PM
Jake_f16's Avatar
Mueckster,
I was kind of thinking the same thing just wasn't sure. I tried to shift into park and it was grinding the gears so I just left it and shut the truck off.
Old 03-09-2014, 09:54 PM
Scerb's Avatar
Scerb Scerb is offline
Scerb is gaining momentum as a positive member of FTE.
Grinding was likely because of what Muekster said. Same effect as trying to go into park while the truck is moving. Assuming nothing got damaged, it probably shifted into park when you shut the motor off.
Old 03-10-2014, 09:43 AM
Jake_f16's Avatar
Thanks guys for the info it is much appreciated.
Need a little help, odd noise and t case question TrailWhale 1999 to 2016 Super Duty 5 10-05-2015 02:13 PM
88 Ranger dies when clutch is released 86f350 Ranger & B-Series 3 07-22-2015 05:05 PM
1968 T18 Trans F100 Mill2580 1967 - 1972 F-100 & Larger F-Series Trucks 2 05-15-2015 08:35 AM
Output shaft spins in neutral? HIO Silver 1973 - 1979 F-100 & Larger F-Series Trucks 10 12-21-2014 10:45 AM
4x4 question [SOLVED] 4x4falcon Clutch, Transmission, Differential, Axle & Transfer Case 4 02-11-2014 03:59 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
