Replacement Speedo Cable Too Long?
I purchased a new speedo cable for my 78 4x4 C6. The cable designated for that application is 118" long per JBG. I bought mine from LMC, but it's the same 118" length. The (original?) cable that I removed is just 83". JBG has cables for other applications in 76" and 95" lenghths.
What do I do with almost 3 feet of extra cable? Would it be better to get the 95" length specified for a '73?
<TABLE style="BORDER-BOTTOM: black 1px solid; BORDER-LEFT: black 1px solid; PADDING-BOTTOM: 0px; BACKGROUND-COLOR: white; MARGIN: 0px; PADDING-LEFT: 0px; PADDING-RIGHT: 0px; BORDER-COLLAPSE: separate; BORDER-TOP: black 1px solid; BORDER-RIGHT: black 1px solid; PADDING-TOP: 0px" class=main cellSpacing=0><TBODY><TR id=table533part0 class=part0 name="pltr533"><TD class=alternate0 rowSpan=2><TABLE class=parts><TBODY><TR><TD style="PADDING-BOTTOM: 0px; MARGIN: 0px; PADDING-LEFT: 0px; PADDING-RIGHT: 0px; PADDING-TOP: 0px" class=left><TABLE style="PADDING-BOTTOM: 0px; MARGIN: 0px; PADDING-LEFT: 0px; PADDING-RIGHT: 0px; PADDING-TOP: 0px" class=layout><TBODY><TR><TD class=partlayout>PIONEER Part # CA3032
3/4 TON and 4 WHEEL/ALL WHEEL DRIVE,95.00" CABLE - PART TIME - 4.9L - 5.0L - 5.8L - 6.6L - 7.5L - FROM SERIAL NUMBER 500001; Base Model
</TD></TR></TBODY></TABLE>rock auto</TD><TD class=right></TD></TR></TBODY></TABLE></TD><TD style="PADDING-TOP: 10px" id=node533part0price class="center leftrightborder boldfont priceonly alternate0">$11.72</TD><TD style="DISPLAY: none; VISIBILITY: hidden" id=node533part0altfiller class="center boldfont leftrightborder pricebreakdown alternate0"></TD><TR id=table533add0 class=part0><TD style="PADDING-RIGHT: 5px; WHITE-SPACE: nowrap; VERTICAL-ALIGN: top; PADDING-TOP: 5px" class="alternate0 center"><INPUT id=node533part0addtocart class=addtocart_default value="Add Part" type=button name=addtocart></TD><TD style="PADDING-BOTTOM: 10px; DISPLAY: none; VISIBILITY: hidden" class="alternate0 center"><INPUT id=node533part0alternate type=checkbox name=alternate></TD></TR><TR id=table533part1 class=part1 name="pltr533"><TD class=alternate1 rowSpan=2><TABLE class=parts><TBODY><TR><TD style="PADDING-BOTTOM: 0px; MARGIN: 0px; PADDING-LEFT: 0px; PADDING-RIGHT: 0px; PADDING-TOP: 0px" class=left><TABLE style="PADDING-BOTTOM: 0px; MARGIN: 0px; PADDING-LEFT: 0px; PADDING-RIGHT: 0px; PADDING-TOP: 0px" class=layout><TBODY><TR><TD class=partlayout>ATP Part # Y818 <INPUT id=node533part1moreinfo class=moreinfo_default title="Click for more information about this part" value=Info type=button> {Click Info Link for Alternate/OEM Part NumbersD3TZ17260H, D4TZ17260M, D7TZ17260J, E0TZ17260D, E0TZ17260Y, E5RY17260B}
4WD; Automatic trans.; W/part time unit; Cable Length 95.00 inches
</TD></TR></TBODY></TABLE></TD><TD style="HEIGHT: 40px" class=right>
</TD></TR></TBODY></TABLE></TD><TD style="PADDING-TOP: 10px" id=node533part1price class="center leftrightborder boldfont priceonly alternate1">$13.79</TD><TD style="DISPLAY: none; VISIBILITY: hidden" id=node533part1altfiller class="center boldfont leftrightborder pricebreakdown alternate1"></TD><TR id=table533add1 class=part1><TD style="PADDING-RIGHT: 5px; WHITE-SPACE: nowrap; VERTICAL-ALIGN: top; PADDING-TOP: 5px" class="alternate1 center"><INPUT id=node533part1addtocart class=addtocart_default value="Add Part" type=button name=addtocart></TD><TD style="PADDING-BOTTOM: 10px; DISPLAY: none; VISIBILITY: hidden" class="alternate1 center"><INPUT id=node533part1alternate type=checkbox name=alternate></TD></TR><TR id=table533part2 class=part0 name="pltr533"><TD class=alternate0 rowSpan=2><TABLE class=parts><TBODY><TR><TD style="PADDING-BOTTOM: 0px; MARGIN: 0px; PADDING-LEFT: 0px; PADDING-RIGHT: 0px; PADDING-TOP: 0px" class=left><TABLE style="PADDING-BOTTOM: 0px; MARGIN: 0px; PADDING-LEFT: 0px; PADDING-RIGHT: 0px; PADDING-TOP: 0px" class=layout><TBODY><TR><TD class=partlayout>PIONEER Part # CA3019 <INPUT id=node533part2moreinfo class=moreinfo_default title="Click for more information about this part" value=Info type=button>
3/4 TON and 4 WHEEL/ALL WHEEL DRIVE,w/118 1/4" CABLE - w/AT - 4.9L - 5.0L - 5.8L - 6.6L - 7.5L; Base Model (Only 8 Remaining)
</TD></TR></TBODY></TABLE></TD><TD class=right></TD></TR></TBODY></TABLE></TD><TD style="PADDING-TOP: 10px" id=node533part2price class="center leftrightborder boldfont priceonly alternate0">$15.84</TD><TD style="DISPLAY: none; VISIBILITY: hidden" id=node533part2altfiller class="center boldfont leftrightborder pricebreakdown alternate0"></TD><TR id=table533add2 class=part0><TD style="PADDING-RIGHT: 5px; WHITE-SPACE: nowrap; VERTICAL-ALIGN: top; PADDING-TOP: 5px" class="alternate0 center"><INPUT id=node533part2addtocart class=addtocart_default value="Add Part" type=button name=addtocart></TD><TD style="PADDING-BOTTOM: 10px; DISPLAY: none; VISIBILITY: hidden" class="alternate0 center"><INPUT id=node533part2alternate type=checkbox name=alternate></TD></TR><TR id=table533part3 class=part1 name="pltr533"><TD class=alternate1 rowSpan=2><TABLE class=parts><TBODY><TR><TD style="PADDING-BOTTOM: 0px; MARGIN: 0px; PADDING-LEFT: 0px; PADDING-RIGHT: 0px; PADDING-TOP: 0px" class=left><TABLE style="PADDING-BOTTOM: 0px; MARGIN: 0px; PADDING-LEFT: 0px; PADDING-RIGHT: 0px; PADDING-TOP: 0px" class=layout><TBODY><TR><TD class=partlayout>ATP Part # Y806 <INPUT id=node533part3moreinfo class=moreinfo_default title="Click for more information about this part" value=Info type=button> {Click Info Link for Alternate/OEM Part NumbersD3TZ17260C, D4TZ17260D, D4TZ17260E, D8BZ17260A, D9BZ17260A, E0SZ17260A, E1BZ17260A, E1SZ17260A, E2BZ17260A, E2SZ17260A, E35Y17260A, E3BZ17260A, E3SZ17260A, E3TZ17260A, E6ZZ17260A}
RWD; Standard trans.; 3 speed trans.; W/custom cab; Cable Length 76.00 inches
RWD; Automatic trans.; W/custom cab; Cable Length 76.00 inches
RWD; Standard trans.; 4 speed trans.; W/custom cab; from serial no. 500,001; Cable Length 76.00 inches
</TD></TR></TBODY></TABLE></TD><TD style="PADDING-TOP: 10px" id=node533part3price class="center leftrightborder boldfont priceonly alternate1">$15.95</TD><TD style="DISPLAY: none; VISIBILITY: hidden" id=node533part3altfiller class="center boldfont leftrightborder pricebreakdown alternate1"></TD><TR id=table533add3 class=part1><TD style="PADDING-RIGHT: 5px; WHITE-SPACE: nowrap; VERTICAL-ALIGN: top; PADDING-TOP: 5px" class="alternate1 center"><INPUT id=node533part3addtocart class=addtocart_default value="Add Part" type=button name=addtocart></TD><TD style="PADDING-BOTTOM: 10px; DISPLAY: none; VISIBILITY: hidden" class="alternate1 center"><INPUT id=node533part3alternate type=checkbox name=alternate></TD></TR><TR id=table533part4 class=part0 name="pltr533"><TD class=alternate0 rowSpan=2><TABLE class=parts><TBODY><TR><TD style="PADDING-BOTTOM: 0px; MARGIN: 0px; PADDING-LEFT: 0px; PADDING-RIGHT: 0px; PADDING-TOP: 0px" class=left><TABLE style="PADDING-BOTTOM: 0px; MARGIN: 0px; PADDING-LEFT: 0px; PADDING-RIGHT: 0px; PADDING-TOP: 0px" class=layout><TBODY><TR><TD class=partlayout>ATP Part # Y848 <INPUT id=node533part4moreinfo class=moreinfo_default title="Click for more information about this part" value=Info type=button> {#D4TZ17260C, D4TZ17260N, D5UZ17260C}
4WD; Automatic trans.; Cable Length 118.00 inches
4WD; Standard trans.; 4 speed trans.; From serial no. 500,001; Cable Length 118.00 inches
</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
1978 F250 4WD C6
Originally Posted by march
JBG says the original cable is 118" long. The (original?) cable I removed is 83" long
JBG is FOS! There are TWO possible cables for your application:
D4TZ-17260-N .. Speedometer Cable-118 1/4" long / Obsolete
Applications: 1974/79 F250 4WD C6.
D7TZ-17260-J .. Speedometer Cable-82" long / Obsolete
Applications: 1974/79 F100/250 C6 4WD; 1978/79 Bronco; 1979 F350 C6 4WD all with part time 4WD / Edit: Notice other applications for this cable in parts catalog chart.
Here are the Genuine Ford Parts speedo cables for 1974/79 F100/250 4WD & 1979 F350 4WD .. and etc.
When the lube dries out, the core binds up inside the housing and snaps.
Auto parts stores sell a universal woven steel core kit. It comes with a separate square end that's installed after the cable is cut to fit.
Make sure to use only a very fine film of graphite or white lithium grease.
D7TZ-17260-J =
WOLFE FORD in Lidgerwood ND has 1 = 701-538-7337.
FRIESEN FORD in Aurora NE has 1 = 402-694-3111.
HASELDEN BROS. in Hemingway SC has 1 = 843-558-2134.
No other Ford dealer, no obsolete parts vendor has any.
alfie623
03-07-2018 11:48 AM
bainenbecky
11-12-2014 07:35 AM
