bronco with a turbocharger - Ford Truck Enthusiasts Forums
Old 03-09-2014, 04:36 AM
beno 420 beno 420 is offline
beno 420 is starting off with a positive reputation.
Did Carroll shell by make a conversion kit for a turbocharger/by rajay turbos in the 1970s
Old 03-09-2014, 11:45 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Carroll Shelby. Yes, post 5 in this link I gave you before mentions having bought one off Ebay:
http://www.ford-trucks.com/forums/53...o-on-351m.html
Old 03-10-2014, 02:33 AM
thanks for the info in new to the computer thing I guess you can say I'm old Xx loved. I just bought this bronco from a old farmer which he passed away; and it has a.400 motor with a Holley carburator with a rajay turbo on it. I can't find any history on it on the Internet your forum is about the only place that I have found with any info about it...I'm haven't even started the truck. Is there anything I should know before I do....if this turbo system is rare and if it is a Carroll shell by product is it worth anything. I'm not sure on what to do with it..thanks
Old 03-10-2014, 01:38 PM
JMO:
Rare-probably
Worth--something, but not a lot
Do with it? --pull it off and rebuild the engine with some compression and a real cam, add headers and 4bbl if you like.
Serving suggestion, ymmv
Check oil and coolant before you start it, not sure what else to check until you find out if it actually still works. Add-on turbos sometimes suffer from coked up oil in the bearings, as there is no oil flow or coolant to mitigate the heat soak after shut down.
You will know pretty quickly I would think.
Old 03-10-2014, 09:49 PM
thanks for the info. I'll let you know if its starts.....
Factory Turbo Removal eutecticpt Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 12-29-2016 07:11 PM
6,7 turbocharger 2011 350 Emel 6.7L Power Stroke Diesel 7 11-14-2016 07:07 PM
could I take a turbocharger of a 7.0 f250 and put it on a 03 5.4 f150 joel22 Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 2 09-02-2016 08:32 AM
460 f250 super/turbocharge 1986-460 Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 5 11-04-2015 01:51 PM
can turbocharger pedestal go bad/how? marveg 1999 - 2003 7.3L Power Stroke Diesel 4 04-09-2005 08:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
