Choice of motor Oil
Old 03-08-2014, 09:04 PM
jonrjen's Avatar
jonrjen
jonrjen is offline
Choice of motor Oil
Wondering what seems to be the chosen brand and weight of motor oil most of you are running in your 6.7.
In my past powerstroke diesels I have always run Rotella 15-40.
But, what say the masses on the 6.7?
Old 03-08-2014, 09:07 PM
rtazz17's Avatar
rtazz17
rtazz17 is offline
I run rotella T6 5w40 synthetic.Ran that in my 7.3 and run it in my 6.7.
Just changed it today.If you have a local walmart they have the gallon jugs with a 5 dollar rebate on each jug.Brought the price down to 16 for a gallon.Not bad.Must be bought in march though.I go 10k miles or one yr whichever comes first.
Old 03-08-2014, 09:18 PM
Tofan's Avatar
Tofan
Tofan is offline
Motorcraft 10W-30 all day everyday. I hear people say good things about Rotella T6, but I change my oil every 5k regardless of how much I drive it. I also use all OEM filters and fluids for the truck.
Old 03-08-2014, 09:24 PM
rtazz17's Avatar
rtazz17
rtazz17 is offline
I go 10k cause its sythetic.Otherwise Id go 5k..But honestly the yr comes b4 10k does in my situation.
My wifes new camry came with sythetic with oil change intervals of 10k recommended by toyota.
Old 03-08-2014, 09:28 PM
Andrew010's Avatar
Andrew010
Andrew010 is offline
5w40 full synthetic. Brand isnt as important as weight IMO. I prefer T6 myself. Motorcraft brand is good stuff as well.
Old 03-08-2014, 10:00 PM
FishOnOne's Avatar
FishOnOne
FishOnOne is online now
Received 1,439 Likes on 888 Posts
Rotella T6 for my truck.
Ford recommends 5W40 for severe service.
Old 03-08-2014, 10:11 PM
TRENT310's Avatar
TRENT310
TRENT310 is offline
0W-40. Helps make the cold starts a bit nicer.
That's inherently synthetic because I don't think that weight is offered in conventional motor oil format.
Old 03-09-2014, 12:03 AM
Tofan's Avatar
Tofan
Tofan is offline
If I used synthetic I would probably go around 10k as well, I tried looking for the Motorcraft Synthetic but couldn't find it. Anybody have a part number?
Old 03-09-2014, 01:20 AM
TRENT310's Avatar
TRENT310
TRENT310 is offline
I don't extend maintenance intervals even if it's synthetic... the oil needs to be changed because of soot particles in suspension, whether or not it's been sheared down or not. Being a 6.0L owner I am concerned about engine oil shearing effects, which don't really seem to be a thing with the 6.7L.
That's the one thing with this truck I haven't really felt a desire to mess with, and that's the oil change reminder interval. I mean apparently living in Canada automatically qualifies my usage as "severe service" anyway.
Old 03-09-2014, 07:07 AM
gsxr1300's Avatar
gsxr1300
gsxr1300 is offline
I use Valvoline Premium Blue Extreme 5w-40
Old 03-09-2014, 07:48 AM
senix's Avatar
senix
senix is online now
Received 1,400 Likes on 997 Posts
Motorcraft 15-40wt. Heavy towing and my numbers always came back good on my 6.4.
Old 03-09-2014, 08:11 AM
gwcon's Avatar
gwcon
gwcon is offline
I use Rotella 15W 40. Not worried about synthetic because I change it every 5K. I am towing 90% of the time.
Old 03-09-2014, 08:46 AM
golfmedik's Avatar
golfmedik
golfmedik is offline
I've got a couple of thousand miles to go before the oil change, but was surprised to see the oil cap recommend 15w30 instead of the traditional 40 wt 'diesel' oil. But then on the bottom reads 5w40....rather odd you think?
Old 03-09-2014, 08:59 AM
OutlawII's Avatar
OutlawII
OutlawII is offline
I use Rotella T5 semi-sythetic 10w30
Old 03-09-2014, 09:36 AM
WildWildWest's Avatar
WildWildWest
WildWildWest is offline
Ford has a wide variety that can be used in the 6.7 depending on conditions.
- Motorcraft Motor Oil 10W30 Super Duty
- Motorcraft Motor Oil 15W40 Super Duty
- Motorcraft Motor Oil 5W40 Super Duty
- Motorcraft Motor Oil 0W30 Super Duty
I use Boss Lubricants Full Synthetic Diesel engine oils (only available in Canada). 0W30 in the winter and switch to 15W40 in the warmer months because that's when I do all the towing. Just went to 15W40 two weeks ago.
Oil changes between 9,000 and 11,000 km (5,600 to 6,800 miles) depending on the conditions which means an oil change every 3 months for me. I let the idiot gauge tell me when to change but always change it out just before going on a month long RV trip where I know I will be putting 6,000 miles on the truck.
Quick Reply: Choice of motor Oil
