Now I'm completely lost, please help!
The MAP connection to Intake the little nipple gets Clogged, also check the hose for cracks, EBP and tube make sure the hole in the sensor is clear not blocked and the tube is clear, IAT2 sensor will be clogged it sits right behind the upper fuel bowl becareful the clip on the connection will snap off it's ok it stays on. Most use a Carb Cleaner I also use a plumbers Flux Brush and
Ware your Safety Glasses that stuff Burns like
Does it get better when it reaches operating temperature?
If so then the cause is more then likely a sticky injector spool!
I have a similar issue and it goes away once operating temp is reached. I had it scanned when it was cold and got an injector code for an injector.
Here's the video of my truck and what its doing. When I pulled out of the driveway and started up the street it was at full throttle. You can here the turbo spooling but she's not going very fast. After get back in the drive way I held the brake and pressed the gas so you can see it smoking. The temp outside was 60 degrees, on colder days (30 and below) if I attempt to drive it will smoke like this. Still no codes!!!! And I cleaned the Map Sensor out.
<iframe width="560" height="315" src="//www.youtube.com/embed/eml-KuVfF1s" frameborder="0" allowfullscreen></iframe>
I don't have a reader capable of reading those parameters except ICP and IPW.
ICP
Idle=1120-1134psi, moving between the numbers (up and down)
Cruise/60mph=2200-2600psi
Accelerating, I've seen it top out at 5000psi plus regularly!
IPW
Idle=130-151ms, moving through the numbers (up and down)
In Drive at a stop= 175-207ms, moving through the numbers (up and down)
Driving/40mph=149-167ms
I don't know what these numbers are supposed to be but are they correct?
ICP
IPW
#29
#30
ICP
IPW
ICP
IPW
