Fuel leak
Old 03-08-2014, 01:30 PM
imjwm's Avatar
imjwm
imjwm is offline
Fuel leak
I have a fuel leak in the v of my 1995 ford f250.I changed the o-rings on the fuel filter canister. Is there an other common place it leaks in there? Or did I not fix something right?
Old 03-08-2014, 01:47 PM
fordpride's Avatar
fordpride
fordpride is offline
The most common are
Orings on the fuel bowl
Fuel pump
Small rubber fuel hoses
Cracks in bottom of fuel bowl
You'll have to clean it up reall good and see where it's coming from
Old 03-26-2014, 05:12 AM
imjwm's Avatar
imjwm
imjwm is offline
I did find my problem. There was a hose clamp that I didn't tighten.
Old 06-21-2014, 04:00 PM
imjwm's Avatar
imjwm
imjwm is offline
I am still having some leaking in the valley of the engine I am thinking it might be the pump. Will changing the seal take care of that or should I replace the pump?
Old 06-21-2014, 05:30 PM
Robbieo11's Avatar
Robbieo11
Robbieo11 is offline
Check the lines that com off the fuel bowl/ reg. that rune to the front of the heads 9/16 head on them see if they are tight. Also inspect them for rott i have 140k on my truck and am replaceing them rite now. Using efi hose hope it works
Old 06-21-2014, 05:57 PM
Hussler's Avatar
Hussler
Hussler is offline
Check this sensor as it is a common leak point. Not out of the thread area but where the wire connection is located. Hard to see because it's usually 1 or 2 drips per second, fuel Filter Restriction Sensor ...
Old 06-21-2014, 10:47 PM
Robbieo11's Avatar
Robbieo11
My hoses where split
fridgeddiesel
36
01-03-2009 08:40 PM
BioNate
07-23-2007 10:59 AM
mikewalsh1
12-28-2004 03:46 PM
wormslinger
1999 to 2016 Super Duty
12-27-2003 09:39 AM
Quick Reply: Fuel leak
