Fuel leak - Ford Truck Enthusiasts Forums
Fuel leak
Old 03-08-2014, 02:30 PM
imjwm's Avatar
imjwm imjwm is offline
imjwm is starting off with a positive reputation.
Fuel leak
I have a fuel leak in the v of my 1995 ford f250.I changed the o-rings on the fuel filter canister. Is there an other common place it leaks in there? Or did I not fix something right?
Old 03-08-2014, 02:47 PM
fordpride's Avatar
fordpride fordpride is online now
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
The most common are
Orings on the fuel bowl
Fuel pump
Small rubber fuel hoses
Cracks in bottom of fuel bowl
You'll have to clean it up reall good and see where it's coming from
Old 03-26-2014, 06:12 AM
imjwm's Avatar
I did find my problem. There was a hose clamp that I didn't tighten.
Old 06-21-2014, 05:00 PM
imjwm's Avatar
I am still having some leaking in the valley of the engine I am thinking it might be the pump. Will changing the seal take care of that or should I replace the pump?
Old 06-21-2014, 06:30 PM
Robbieo11's Avatar
Robbieo11 Robbieo11 is offline
Robbieo11 is starting off with a positive reputation.
Check the lines that com off the fuel bowl/ reg. that rune to the front of the heads 9/16 head on them see if they are tight. Also inspect them for rott i have 140k on my truck and am replaceing them rite now. Using efi hose hope it works
Old 06-21-2014, 06:57 PM
Hussler's Avatar
Hussler Hussler is online now
Hussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to all
Check this sensor as it is a common leak point. Not out of the thread area but where the wire connection is located. Hard to see because it's usually 1 or 2 drips per second, fuel Filter Restriction Sensor ...
Old 06-21-2014, 11:47 PM
Robbieo11's Avatar
My hoses where split
7.3 (1999) Fuel Bowl Leak Natalie7.3 1999 - 2003 7.3L Power Stroke Diesel 9 10-03-2015 10:18 PM
Fuel leak at electrical sensor in fuel filter housing Stephenn95 1994.5 - 1997 7.3L Power Stroke Diesel 7 04-19-2015 02:01 PM
fuel leak tommy6866 6.0L Power Stroke Diesel 7 11-24-2014 11:25 PM
Fuel leak Larryd8563 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 10-17-2014 03:50 PM
Fuel filter leak renoduckman 1999 - 2003 7.3L Power Stroke Diesel 4 08-17-2014 11:40 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
