distributor gear and comp cams
plus i cant fine one for the 4.9...all i come up with is a bronze one..
Cast iron and composite gears are suited for hydraulic and solid flat tappet cams, while melonized steel and composite gears mesh with austempered ductile iron hydraulic and solid roller cams, or those camshafts that have been nitrided. Finally, either bronze or composite distributor gears are your options if your camshaft is a billet steel hydraulic or solid roller.
Selecting The Correct Distributor Gear - CPG Nation Forum
Assuming you're talking about the 252h, 260h or 268h cams then the stock cast iron dist. gear is the ticket.
http://www.summitracing.com/parts/cca-cl66-236-4
so do i need to change it?
restoringmy46
11-28-2011 10:15 PM
piperig78
03-29-2011 09:34 PM
gnwalker
01-23-2010 11:44 AM
1982fordf100
05-10-2006 09:09 AM
lmadore
10-25-2005 07:53 AM
