Diesel Tank Cleaning What To Use.
Today I was out and about and got my hands on an aluminum diesel fuel
tank. Not too bad but it does need to have the inside cleaned.
I can post the dimensions later. I did peek in it and it does have
baffles and what looks like dirt along with some diesel.
What would be the best thing to use to get all the crap cleaned out?
Sean
Sean
Josh your up later or is it early?
The tank is from a Mac or a Kenworth. So it's BIG but not so big that it won't fit
side to side in the bed. The thing is can I ever afford to fill it. I think it about 150 Gal.
So lets say I do fill it at $3.809 X 150 = $571.35 Holy Sheep dip!
AND 150 X 7.15 Lb = 1072.5 Lb for a full tank. That will drop the MPGs a bit.
So just a guess at lets say 19 MPGs empty. I see about 21.5 unloaded so
150 +38 X 19 = 3572 mile range.
Do you know if there is a rule/law on how much extra fuel you can carry?
Sean
Sean
Sean
Sean
Depends on GVW of the truck, over 10k and under 10k.
The rule of thumb is no more than 150 gallons of total fuel of all tanks.
Hence why you see so many new transfer tanks for 109 gallons, just in case.
And no way would one get 19mpg with 1100 pounds in the bed. My 2005 weighed 9900+ pounds and on a good day get 17.
Josh
Josh
Just fabricate a box-like cover for it with some unpainted sheetmetal that will rust and look like crap! People will think you're just on the way to the scrap yard.
Josh
Josh
MPG would go up as the tank empties.
taking home.
Thanks for all the good ideas,
Sean
you can legally carry that amount. Some over the road trucks will have two 150 gallon tanks. You don't need a tanker or hazmat endorsement for that amount of fuel. I "think" that you are good for up to 500 gallons before needing a hazmat, and up to 999 gallons of fluid before needing a tanker endorsement. This all pertains to having a CDL, but I would assume that all cases are subject to the same laws. you certainly would fall well below the minimum guidelines for commercial carriers. However, when you have a visible bulk tank in the back of your private truck, you are subject to get pulled at random by a Motor Carrier Safety Patrol officer(D.O.T State Trooper) to get the fuel in your on board tank inspected for Off Road Diesel.
Hazmat endorsement (and then CDL) is needed if your slip tank is over 119 gallons for diesel fuel.
The truck's tanks don't play into that.
If you need a hazmat you need a tankers endorsement and a CDL.
You need a CDL before you can need a tanker endorsement otherwise.
You are dangerous.
However, thanks for clearing that up.
GVW of the vehicle most certainly applies to extra fuel tanks:
(4) Exception. The following previously exempted vehicles are not required to carry the certification and marking specified in paragraphs (f)(1) through (3) of this section:
(i) Ford vehicles with GVWR over 10,000 pounds identified as follows: The vehicle identification numbers (VINs) contain A, K, L, M, N, W, or X in the fourth position.
(ii) GM G-Vans (Chevrolet Express and GMC Savanna) and full-sized C/K trucks (Chevrolet Silverado and GMC Sierra) with GVWR over 10,000 pounds identified as follows: The VINs contain either a “J” or a “K” in the fourth position. In addition, the seventh position of the VINs on the G-Van will contain a “1.”
Fuel Tank Regulations - Transfer Flow, Inc. - Aftermarket Fuel Tank Systems
Josh
Josh
