Diesel Tank Cleaning What To Use. - Ford Truck Enthusiasts Forums
Old 03-08-2014, 01:32 AM
Yahiko's Avatar
Yahiko Yahiko is offline
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
Today I was out and about and got my hands on an aluminum diesel fuel
tank. Not too bad but it does need to have the inside cleaned.
I can post the dimensions later. I did peek in it and it does have
baffles and what looks like dirt along with some diesel.
What would be the best thing to use to get all the crap cleaned out?
Sean
Old 03-08-2014, 02:04 AM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
Take it to a radiator shop and have it hot tanked.
Josh
Old 03-08-2014, 02:54 AM
Yahiko's Avatar
Josh your up later or is it early?
The tank is from a Mac or a Kenworth. So it's BIG but not so big that it won't fit
side to side in the bed. The thing is can I ever afford to fill it. I think it about 150 Gal.
So lets say I do fill it at $3.809 X 150 = $571.35 Holy Sheep dip!
AND 150 X 7.15 Lb = 1072.5 Lb for a full tank. That will drop the MPGs a bit.
So just a guess at lets say 19 MPGs empty. I see about 21.5 unloaded so
150 +38 X 19 = 3572 mile range.
Do you know if there is a rule/law on how much extra fuel you can carry?
Sean
Old 03-08-2014, 05:55 AM
diggintrenches's Avatar
diggintrenches diggintrenches is offline
diggintrenches is starting off with a positive reputation.
Sean
you can legally carry that amount. Some over the road trucks will have two 150 gallon tanks. You don't need a tanker or hazmat endorsement for that amount of fuel. I "think" that you are good for up to 500 gallons before needing a hazmat, and up to 999 gallons of fluid before needing a tanker endorsement. This all pertains to having a CDL, but I would assume that all cases are subject to the same laws. you certainly would fall well below the minimum guidelines for commercial carriers. However, when you have a visible bulk tank in the back of your private truck, you are subject to get pulled at random by a Motor Carrier Safety Patrol officer(D.O.T State Trooper) to get the fuel in your on board tank inspected for Off Road Diesel.
Old 03-08-2014, 08:41 AM
Bullitt390's Avatar
Depends on GVW of the truck, over 10k and under 10k.
The rule of thumb is no more than 150 gallons of total fuel of all tanks.
Hence why you see so many new transfer tanks for 109 gallons, just in case.
And no way would one get 19mpg with 1100 pounds in the bed. My 2005 weighed 9900+ pounds and on a good day get 17.
Josh
Old 03-08-2014, 11:13 AM
mattdoc88 mattdoc88 is offline
mattdoc88 is gaining momentum as a positive member of FTE.mattdoc88 is gaining momentum as a positive member of FTE.
Quote:
Just fabricate a box-like cover for it with some unpainted sheetmetal that will rust and look like crap! People will think you're just on the way to the scrap yard.
Old 03-08-2014, 01:02 PM
Yahiko's Avatar
Josh
Yep, The 19 was just a stab at a number. Still even 17 MPG. Also that
MPG would go up as the tank empties.
Quote:
That is a good idea. Or even a wood box that makes it look like a crate your
taking home.
Thanks for all the good ideas,
Sean
Old 03-09-2014, 05:14 AM
Crete Crete is offline
Crete is starting off with a positive reputation.
You are dangerous.
Hazmat endorsement (and then CDL) is needed if your slip tank is over 119 gallons for diesel fuel.
The truck's tanks don't play into that.
If you need a hazmat you need a tankers endorsement and a CDL.
You need a CDL before you can need a tanker endorsement otherwise.
Old 03-09-2014, 05:16 AM
No it doesn't.
Ummmm. No it isn't.
Old 03-09-2014, 09:56 AM
Quote:
Originally Posted by Crete View Post
You are dangerous.
Dangerous?! probably not. If you read closely, I used the word "think" which means that it is subject to further input and research. I have had my Class A CDL since 1990, however....I have stayed away from tanker and hazmat endorsements for personal reasons and have not brought myself up to date on the laws of hazmat and/or tanker. I do know that when I first got my CDL, I was allowed to drive a water tanker that carried less than 1000g legally without a tanker endorsement.
However, thanks for clearing that up.
Old 03-09-2014, 10:54 AM
Bullitt390's Avatar
No it doesn't.
Ummmm. No it isn't.
GVW of the vehicle most certainly applies to extra fuel tanks:
(4) Exception. The following previously exempted vehicles are not required to carry the certification and marking specified in paragraphs (f)(1) through (3) of this section:
(i) Ford vehicles with GVWR over 10,000 pounds identified as follows: The vehicle identification numbers (VINs) contain A, K, L, M, N, W, or X in the fourth position.
(ii) GM G-Vans (Chevrolet Express and GMC Savanna) and full-sized C/K trucks (Chevrolet Silverado and GMC Sierra) with GVWR over 10,000 pounds identified as follows: The VINs contain either a J or a K in the fourth position. In addition, the seventh position of the VINs on the G-Van will contain a 1.
Fuel Tank Regulations - Transfer Flow, Inc. - Aftermarket Fuel Tank Systems
Josh
Old 03-10-2014, 02:55 AM
AlaskanF350 AlaskanF350 is offline
AlaskanF350 is gaining momentum as a positive member of FTE.AlaskanF350 is gaining momentum as a positive member of FTE.
what about inbed tank to self-haul heating oil?
DMV (Alaska) told me can use up to a 200 gallon tank, as long it wasn't plumbed into the vehicles fuel system, without a CDL or plaque'ding
Chris
Old 03-10-2014, 03:18 AM
Yahiko's Avatar
Well my intended use was to SoCal and back along with the trip
to the big meet this spring. So I have to see about the rules on
the way there and back. I would not have it linked to the truck
system. I would use a pump and a nozzle to move it.
Sean
Old 03-10-2014, 03:51 AM
Just had DOT site up and F350's are exempt from placarding and driver certification.. for "inbed external fuel tank"
thought I was smart and re-open this thread--
now can't find the address for the DOT
I never claimed to be literate >>>
Chris
Old 03-10-2014, 03:52 AM
I believe that is what Bullitt was telling us..
Chris
Would you use a Dorman... Yahiko 6.0L Power Stroke Diesel 24 12-31-2014 10:56 PM
Anyone know the micron size of the fuel filters? Yahiko 6.0L Power Stroke Diesel 2 09-05-2014 07:47 AM
E-series Vacuum pump question. Yahiko 6.0L Power Stroke Diesel 3 08-06-2014 06:12 PM
DieselTechRon makes it look way too easy Yahiko 6.0L Power Stroke Diesel 7 03-29-2014 08:48 PM
Injector question. Yahiko 6.0L Power Stroke Diesel 36 03-21-2014 12:23 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
