Possible bad injector.
Hey everyone, new to this site, and I thought I would start off with a question. I have a 96 3/4 ton with a 7.3 and 200000 miles. I recently replaced the infamous injector wiring harness including the pigtails that plug into the valve cover gaskets. I also replaced the glow plug relay while I was at it. Now upon firing I am only running on what seems to be 7 cylinders, and there is oil in my fuel bowl and on my fuel filter. My guess is it could be a bad injector? I still want to pull the valve cover off and see if I may have missed a plug or something. Is there a way to pull the injector out and bench test it? Is there anyway an injector can get clogged? Any other ideas on why I don't have the cylinder firing? Oh I should also say it sat for 6 months prior to me trying to get it going. Ps. I know this has probably been covered but I'm mobile only right now and the search feature couldn't seem to find what I wanted.
Welcome to FTE !
If you have oil in the fuel bowl then you have bad injector orings.
You can't diy bench test these injectors.
Pull the valve cover and unplug A injector then start the truck if it makes a difference in the way it runs shut it off plug it back in a do another.
Keep repeating till you find the one that makes no difference
Ok cool, thanks for the welcome! Yeah, I think I have it narrowed down to one of the two in the back on the passenger side. I have heard a few different locals say you can rebuild injectors, so does a bad oring constitute a possible rebuild? The wallet is a little thin right now, and the cost of a new injector doesn't sound so good.
Bubba Jones
24
05-21-2016 08:11 PM
fixitman1310
04-15-2010 07:43 PM
MarkSullivan
12-04-2009 09:02 PM
