If you could build any engine for your truck
I have also looked at that path but I worry that I'll only get 5-6 mpg and that won't be fun on a 35 mile drive to the lake.
The IDI's are (almost) never fast, but they will always get you there. I don't think even the 300-6 can touch a decently maintained IDI in reliability.
Easy Choice.
Top of the morning dedicated Forum Brothers and Sisters.
For my engine I would use the McLaren P1's 3.8L, 727-HP, 720-lb-ft twin turbocharged V8 hybrid 903 hp, 900 lb-ft net system output; RWD, seven-speed dual-clutch sequential manual trans.
I would mate it to a Aluminum Ford 2015 changing the suspension to a F1 type double-wishbone F/R with an abundant amount of carbon fibre.
You said money was no object.
Boon
Postscript: Supercars is a longtime passion of mine.
Boon
I'll be the realist here, and I mean no offense.
From reading different threads about what you want to do with your truck, it's pretty apparent that the truck you have is not the truck you want and/or need. Trying to make it into that can get spendy in a hurry, and also frustrating if things aren't happening fast enough.
My suggestion would be to sell or trade your current truck for something that fits your needs/wants better, and is easier to modify into what you want.
An F350 IDI seems like a good platform to start with. Solid axles, heavier duty frame and suspension for 35s, decent fuel economy, and easily modified to make acceptable power.
Of course, a Powerstroke OBS would be ideal, but purchase price becomes a factor. At least in my neck of the woods. Rotted out poorly maintained Powerstrokes seem to have asking prices upwards of $7k, because OMGDIESEL.
You're actually right on all that, my ideal truck is an obs with a 7.3 powerstroke. It basically has all the things I want, it's just not economical to buy one right now.
I like turning wrenches though. My truck currently does everything I "need" it to do. I just like projects. I think a gasser engine swap wouldn't be a big deal and I can do a build over a few months and swap it in over a long weekend.
In that case, with fuel economy and performance in mind with a gas engine, I'd go with a basic 351 build. Since it'll be done over time, skip the GT40 head route and go for something aftermarket that'll perform better. Decent cam, MAF swap, ZF trans, and I think you'll have a fun truck. If your plan is still to run 35s, I'd go with a solid axle front swap, 6" lift, and 4.56 gears. Simple and reliable setup.
I hear ya man. Mine does everything I need it to do also, but I keep coming up with ideas... lol.
That sounds like a good base, I only get about 13-14 mpg as it is so a small block would probably do better unless I boost it.
Putting a diesel in a half ton might not be such a good idea. The frame won't stand up to the torque very well. At least that's what I've heard.
I picked up my Fully loaded 97 F250 HD 460 XLT Lariat in better shape for $5500... The extra cost of the Diesel just ain't worth it to me. I'm happy with my 460. She doesn't get great mileage, but diesel is 15-20 cents a liter more here, and I don't have the added maintenance costs.
That being said, if anything happens to the engine in my truck, another 460 will be going in, no question about it. Has all the power I need and then some, and is one of the most reliable engines produced IMHO.
#30
There is a '97 F250 HD Power Stroke sitting at the Ford dealership in town here. Its an XL, bare bones, Ok shape but nothing spectacular. They want $13,000. Didn't even bother to ask how many miles were on it
Diesel here averages .80 cents to as much a buck a gallon more than gasoline.
Not enough difference 460 / PS to offset the added expense for the truck itself buying in or the fuel it'd require that point forward.
