226 6 cyl fan belt
Old 03-07-2014, 07:06 PM
awjjim's Avatar
awjjim
awjjim is offline
226 6 cyl fan belt
Anyone have part numbers or belt size for 1949 F4 226 6 cyl wide fan belt water pump and generator/alternator. I have done the 12v conversion with alternator. I got a belt from NAPA but it is only large enough for the water pump.
Old 03-07-2014, 07:16 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
TR28423 is the Gates # I see At my parts supplier's site
Old 03-07-2014, 07:21 PM
harleymsn's Avatar
harleymsn
harleymsn is offline
Here you go. I highlighted the original. If the alternator is in the same location as the generator and the same size pulley it should work, otherwise you may need the next one which is about 2" longer. If you can verify the length that should make it easy.
Old 03-07-2014, 07:23 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
Those are close to the gates belt dimensions
Old 03-07-2014, 07:34 PM
harleymsn's Avatar
harleymsn
Yea, the Gates is about .05" longer which should pose no problem so long as the length needed is the same as original. Guess I was sniping the chart while you were posting, good job.
Old 03-07-2014, 07:39 PM
awjjim's Avatar
awjjim
awjjim is offline
Great, I will try to source one tomorrow. Thanks
Old 03-07-2014, 07:42 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
Thanks , just trying to help
Old 03-08-2014, 06:43 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
C9PZ-8620-FH (replaced 7HT-8620-A) .. Fan Belt / Obsolete
NOS PARTS LTD in Waxahachie TX has TWO = 972-937-2201.
CARPENTER NOS OBSOLETE PARTS in Concord NC has TWO = 800-476-9653.
Old 03-08-2014, 08:46 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
I really wouldn't want an NOS belt, no telling how old it is. NAPA appears to have it in stock:
NAPA AUTO PARTS - Ford 226 Belt
Old 03-08-2014, 10:12 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
I wonder ... . The belt on my TO20 ... installed 1985 , still going . My 53 Pontiac ... belt s a bit older .... There are many factors ....
Old 03-09-2014, 08:05 AM
NumberDummy
What do you think the NAPA belt is? More than likely...NOS! How long has it been layin' around?
When was the last time anyone remade any of these fan belts?
Hugh Jones
03-31-2022 12:41 PM
now_what
06-08-2013 10:40 PM
Midnite1987
07-15-2012 05:28 PM
82inline6
07-11-2012 08:58 PM
JoshDacres
12-13-2011 09:52 AM
Quick Reply: 226 6 cyl fan belt
