Where is the best place to hook a chain to the 360 from a cherry picker to pull it and the connected transmission out of the truck. The entire front end is off and out of the way, so it should be a simple task once I get some feed back.
The entire front-end assembly has been removed. No core support, fenders or any of that stuff, its all out of the way. I ill be using just a chain and not an engine tilting sling.
Originally Posted by rockittsled
then pull the alternator and use that bolt hole and the matching bolt hole at the back of the driver side head
...Then 2x with Rockittsled. Also slide a latex glove over the tailshaft housing or else it'll be a bloody scene of ATF.
