2015 F150 possible mpg improvements - Ford Truck Enthusiasts Forums
2015+ F150 Discuss the 2015 Ford F150 SPONSORED BY:
Old 03-07-2014, 09:31 AM
CatBob CatBob is offline
CatBob is starting off with a positive reputation.
In the early 70's I drove a ford box truck with a 2 speed rear differential. I would like to see this put into the new F150's. Best of boyh worlds. MPG's and towing capacity. What do you think.
Old 03-07-2014, 11:21 AM
Frdtrkrul Frdtrkrul is offline
Frdtrkrul has a good reputation on FTE.Frdtrkrul has a good reputation on FTE.Frdtrkrul has a good reputation on FTE.
I feel when the new 10 speed autos come out later next year or 2016 the mileage will improve more significantly. Or the laws of diminishing return could prove this wrong.
Old 03-07-2014, 01:38 PM
Seems to me, even with a 10 speed trans, being able to switch between a 3.15 diff and a 3.73 would be a plus. It would help ford to meet the new cafe standards. 3 or 4 mpg hwy adds up.
Old 03-07-2014, 02:19 PM
texastech_diesel's Avatar
texastech_diesel texastech_diesel is offline
Disgruntled Texan
texastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputation
You realize that's how the automatic transmissions work now, right? Instead of a split diff, there's a second gear set in the trans. A "6 speed" isn't 6 separate forward gears, is a 3 speed auto in front of an overdrive unit that combines 3 gears with 2 for six total. It's a manual trans and a split axle all combined into a single unit. It's been like this since 2003 when the 5R110W came out; there are six total gear combinations but only 5 are used.
Old 03-08-2014, 06:53 PM
The 6R140 is a double OD not a triple. 4 forward gears with double ODs. Same with the Allison 1000 after they changed it.
The 8 and 10 speeds would be like having an old 4 speed manual and a Gear Vendors Gear splitter/OD unit all in one.
2017 SD will be great for F150 sales. elemint 2017 Super Duty 5 10-08-2015 06:54 AM
Bad MPG with 5.4 Grappler150 Modular V8 (4.6L, 5.4L) 5 01-27-2014 08:55 AM
callibrating mpg gauge? jyarosz 2009 - 2014 F150 4 06-29-2012 11:31 PM
Lift/ mpg? rangergirl94 1987 - 1996 F150 & Larger F-Series Trucks 8 02-16-2012 10:49 PM
What mpg you get out bronco and list what you did to get good mpg Milwaukee1979F150 1978 - 1996 Big Bronco 29 09-30-2009 03:14 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
