oil & fuel filter cap removal; a third option
Old 03-07-2014, 07:08 AM
bbender85's Avatar
bbender85
bbender85 is offline
so it's pretty common knowledge around here that using a 1/2" driver on the filter caps is a no-no, and to use the large socket instead. well i've been using neither of those provisions the last few times i've done filters.
perhaps this has been discussed before, but i've not seen it come up in the almost two years i've been dropping into the 6.0l forum:
i've been using an actual oil filter wrench that i've had sitting around from previous vehicles, that in a pinch i tried on the oil and fuel filter caps.. and it works like a dream.
it puts a nice even pressure around the perimeter of the cap, and the harder you turn the more it grips. it has proved to work pretty well for removing the lower fuel filter, with the front driveshaft in place (once you figure out how to work with it in that spot)... alot less cumbersome and more compact than a ratchet. again, maybe this is common knowledge, but i hadn't seen it discussed and thought i'd share.
happy friday!
Old 03-07-2014, 07:55 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
I have a couple of those filter wrenches. I'll give it a shot next time. Thanks for the tip!
Old 03-07-2014, 11:07 AM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
I use the filter wrench for the frame fuel filter.
Josh
Old 03-07-2014, 11:21 AM
diggintrenches's Avatar
diggintrenches
diggintrenches is offline
Great idea.
Old 03-07-2014, 01:55 PM
KDAVID1's Avatar
KDAVID1
KDAVID1 is offline
you just saved me some money
fordtruggy
6.4L Power Stroke Diesel
02-20-2013 09:56 PM
23larry24
08-17-2011 10:19 AM
MauleOne
09-18-2010 12:24 AM
droffan
06-08-2010 06:08 PM
Skeetshooter
13
09-18-2002 03:42 AM
Quick Reply: oil & fuel filter cap removal; a third option
