How do you test a brake controller
My 90 F250 already had a brake controller installed when I bought it, but I've never towed anything with it yet. Just got a race car and trailer now and would like to test it out (my dad towed it up, so it still hasn't been hooked up to my truck).
Testing the lights is pretty straight forward but is there a way to test the brake controller other than just hooking up and going for a drive?
On the controller itself, there should be a slider mechanism that you can slide with your hand. That applies the trailer brakes independent of the truck. In a suitable location, put your truck in drive, slide the thing on the controller, and take your foot off the brake. The trailer brakes should hold you back. If not, adjust the gain (a dial or buttons) up until you get some resistance from the trailer brakes. If nothing still, either the trailer brakes are out of adjustment or you are not getting power to the plug at the back of the truck. That should be part of a pre-trip inspection EVERY TIME the trailer hits the road.
Now doing that will tell you the controller is sending power to the plug, but it will not tell you how your truck and trailer work together and that is the crucial factor in trailer braking. That means you have to be hitched and moving to make sure everything is working.
Steve
My initial test when hooking up a new system is to get it all wired, then jack up the trailer axle to get the wheel off the ground, spin the tire and apply the brakes to see if they work. Repeat for each braked wheel.
Then I go for a gentle drive to see if they work on the road and adjust the controller if needed.
Steve
Starting off very slow and applying the brake manually will help with the bias. To the other's point, always good to test in a safe area. When stopping, you should get a smooth feel when almost stopped. If it jerks, too much bias.
Most aftermarket controllers have essentially a coarse and fine adjustment and you will need to get both right.
You will have to play with it a bit to feel comfortable.
In this case, too much is just as bad as not enough IMHO.
Not sure I would say just as bad, but certainly not good. If it's enough too much you'll skid your trailer tires which will make them out of round and can quickly wear them to the cord.
Don't ask me how I know, but I'll plead youth
Actually it was also the brake set up on my dad's 77 F-150 with hydraulic actuated brake controller. Even dialed to the lowest setting it would skid the tires when the trailer was empty.
The addition of an external rheostat solved the problem.
Steve
A lot of good information has been posted above - copied and posted below is from the FORD owner's manual on how to adjust - test the trailer brake controller
As with all of my posts take and use what you find useful - disregard the rest
Procedure for adjusting GAIN:
The GAIN setting is used to set the TBC for the specific towing condition
and should be changed as towing conditions change. Changes to towing
conditions include trailer load, vehicle load, road conditions and weather.
The GAIN should be set to provide the maximum trailer braking
assistance while ensuring the trailer wheels do not lock when braking;
locked trailer wheels may lead to trailer instability.
Note: This should only be performed in a traffic-free environment at
speeds of approximately 20–25 mph (30–40 km/h).
1. Make sure the trailer brakes are in good working condition, functioning
normally and properly adjusted. See your trailer dealer if necessary.
2. Hook up the trailer and make the electrical connections according to
the trailer manufacturer’s instructions.
3. When a trailer with electric brakes is plugged in, the TRAILER
CONNECTED message displays in the instrument cluster message center.
4. Use the GAIN adjustment (+/-) buttons to increase or decrease the
GAIN setting to the desired starting point. A GAIN setting of 6.0 is a
good starting point for heavier loads.
5. In a traffic-free environment, tow the trailer on a dry, level surface at
a speed of 20–25 mph (30–40 km/h) and squeeze the manual control
lever completely.
6. If the trailer wheels lock up (indicated by squealing tires), reduce the
GAIN setting; if the trailer wheels turn freely, increase the GAIN setting.
Repeat Steps 5 and 6 until the GAIN setting is at a point just below
trailer wheel lock-up. If towing a heavier trailer, trailer wheel lock-up
may not be attainable even with the maximum GAIN setting of 10.
You may have an wheel to adjust the gain rather than push buttons - but same idea.
lever completely.
I think the responses kind of went down two different channels as I interpreted the OP's post asking how to know it was working, not how to adjust it. Maybe others did the same. Of course, after you know it is working, you still have to adjust it, so it is all good.
Steve
Steve
Steve
Steve
In this day and age - how many times have we heard or read about a vehicle with a problem going to the shop and the shop saying everything tested ok. Especially with electrical issues and connections.
So in my defense - and yes I strayed from a strict interpretation of the original question (a little) - but the best way to know if something is working properly is try it and in order to try the brakes the proper gain must be set.
I check my brakes that way when I hook up a loaded trailer - every time.
again my 2 cents - take it or leave it
Very good point. A person should know the setting for their empty trailer (assuming a cargo/flatbed trailer), and the setting for an "average" load. Once loaded, set it at your average (so you have at least some brakes), then test and fine tune before making your trip.
Steve, you are correct - responses drifted a bit from the original question - but for me - and that is just me - the only way to really test to see if the brakes are actually working properly is to use them. All the electrical connections in the world can be tested - and be fine - but the ultimate test is do they actually work properly - which is why I posted the excerpt from the owner's manual about adjusting the gain. Following those simple instructions and he will know if they are working or not. If not he could work backwards thru the connections etc for determine the problem.
Steve
Your test procedure is actually something I always do with a heavy truck as well, though that's to check that the kingpin is locked no so much that the trailer brakes are working (though it does that too).
