5.4L Parts Cost - Ford Truck Enthusiasts Forums
5.4L Parts Cost
Old 03-06-2014, 08:40 PM
Vadis's Avatar
Vadis Vadis is offline
Vadis is starting off with a positive reputation.
5.4L Parts Cost
Long story but I got my hands on basically a long block kit not assembled for nothing. All the components are machined (crankshaft, heads, block) and wrapped up for storage. It also came with oil pan, oil pump, complete gasket set, piston ring set, main and rod bearing sets, head bolt sets for both heads, timing cover set and rear main seal.
Supposedly it's a 2000-2001 supercharged 5.4L but I'm not sure if that's 100% accurate info. Anything I can check for to confirm what it is?
Now I have no use for this as I don't run anything that new, so I was going to list it up for sale locally.
I went through summit racing and added up the parts (minus the heads and block) and the total comes up to about $1000, but that's brand new prices.
I hate to be one of those people that asks because it's so varied from place to place but what would be a good ball part to list all this stuff at?
Old 03-07-2014, 10:09 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Are the pistons dished or flat top? Dished would probably mean they are low compression for a supercharged engine. I would start around $750 and see how it goes.
Old 03-07-2014, 10:25 PM
Vadis's Avatar
It didn't come with con. rods or pistons. Not sure why those are missing but those, timing cover and the cams are missing. I haven't gotten a great look at everything on the pallet but I'm going through it tomorrow, so I'll have a complete list tomorrow.
Old 03-08-2014, 06:01 PM
Vadis's Avatar
Well I got to check out everything in greater detail today and get some pictures. The gasket set said 2000-2001 5.4L except supercharged versions. So that answers that question.
Here are some pictures including some casting #'s
Heads
Crank
Block
Which oil pump 351m 4x4 PapaBearYuma 1973 - 1979 F-100 & Larger F-Series Trucks 7 11-12-2016 10:48 AM
302 question papabills54 Performance & General Engine Building 2 11-07-2016 02:26 PM
First Engine Rebuild - 5.4 2v Austin J. 1997 - 2003 F150 10 08-26-2016 07:00 AM
helicoil or new heads officespace2 1968-2013 Full Size Vans 10 12-30-2015 10:45 AM
How To Change Oil pan / Gasket / Pump / Pickup with Motor Still in Truck (300 Straight Six) mark1986F150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 03-13-2015 08:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
