302 EFI to 302 EFI HO swap? - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
Old 07-01-2003, 04:06 PM
Liquid0228 Liquid0228 is offline
Liquid0228 is starting off with a positive reputation.
I have an 1987 Bronco that I think has a bad main bearing so I thinking of replacing the motor instead of selling it. I currently have a stock 302 EFI and C-6 transmission. I've done a good bit of searching lately and it seems I can find tons of really nice 302 EFI HOs but not nearly as many 302 EFI's.
What I really want to know is are the blocks the same, can I use the intake from my truck and will and engine from a mustang mount to my C-6 transmission. So far I have found out that the firing order may be different, which I guess shouldn't be a problem if I use the distributor from the donor car. Also I keep hearing that I cannot use the mustang headers (something about the dipstick).
Has anybody done this particular swap and if so how difficult was it and what other parts did you have to swap.
Thanks is advance for your reply!
Old 07-02-2003, 01:04 PM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
everything will swap over even the distributor. its the computer that will need swapping out to correct the new firing order of the HO motor. mustang headers can work but you will need to get the y pipe redone to mate to the headers properly
carb vs efi drileybond Fuel Injection, Carburetion & Fuel System 5 03-05-2012 11:49 PM
351M to 302 HO EFI jleinweber Engine Swaps 2 12-20-2004 03:12 PM
84 302 to 87/88 ho swap! kygn87 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 8 06-08-2004 08:52 PM
5.0/302 swap for 80's ranger. Matts72 Ranger & B-Series 4 11-13-2003 03:01 PM
efi tranny nickname_86 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 08-24-2003 01:42 PM
Tags
302, 302efi, efi, ho, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
